which direction for rods In B18A?
Old Jun 19, 2004 | 12:02 PM
hondaguyef's Avatar
Default which direction for rods In B18A?
Should the side with the hole in the rod for the oil to travel to the rod bearing face to the front of the block(dipstick side) or to the rear? TIA!
Old Jun 19, 2004 | 04:06 PM
3rdGteg's Avatar
Default Re: which direction for rods In B18A? (hondaguyef)
Connecting rod oil hole must face the rear side of the engine. Also, the arrow on top of the pistons should be pointing towards the timing belt side, so this should tell you already about the rod oil hole (that's if the pistons are on correctly).
Hth.
Old Jun 20, 2004 | 04:38 AM
hondaguyef's Avatar
Default Re: which direction for rods In B18A? (3rdGteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3rdGteg &raquo;</TD></TR><TR><TD CLASS="quote">Connecting rod oil hole must face the rear side of the engine. Also, the arrow on top of the pistons should be pointing towards the timing belt side, so this should tell you already about the rod oil hole (that's if the pistons are on correctly).
Hth.</TD></TR></TABLE>
Did not come w/ pistons. thanks though
OasU
Jun 13, 2012 01:33 PM
zenon8890
Sep 25, 2010 09:03 AM
mario_pic
Mar 15, 2010 01:35 PM
torbs
Mar 20, 2006 12:22 PM
jakscivic
Jan 13, 2006 02:48 PM
