How many of you have 450+hp with a 3" full exhaust (minus cat).
Old Jun 19, 2004 | 10:58 AM
AlphaKennyWun's Avatar
Default How many of you have 450+hp with a 3" full exhaust (minus cat).
I hope there are alot of you out there because I cant find 3.5" mandrel bent exhaust. Im thinking of getting a Kteller 3" exhaust, 3" dowpipe and 3.5" (5" x 8") magnaflow muffler from Jegs.
Im running 14 psi on a SC61 9:1 compression B18c built motor. I have a 2.5" dowpipe to 2.25" cat back exhaust and a stock IM that I think are the reasons for my low numbers (see sig). Also hondata is tuned pretty conservative 11:1 a/f or 10.5:1 a/f on boost if i remember correctly. Im going to get those things changed and put springs and retainers in the head. Im shooting for 25 psi - 28 psi (450hp+ I hope) using the new full 3" exhaust. Just wondering now if the 3" is adequate and/or if goals are attainable
Modified by Turbo Chris at 3:11 PM 6/19/2004
Old Jun 19, 2004 | 11:02 AM
Casey's Avatar
Default Re: How many of you have 450+hp with a 3" full exhaust (minus cat). (Turbo Chris)
im sure there are a few. but on a similar note, would you make more power and or spool quicker with 3.5"? thanks
Old Jun 19, 2004 | 11:35 AM
HXMan's Avatar
Default Re: How many of you have 450+hp with a 3" full exhaust (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote"> would you make more power and or spool quicker with 3.5"? thanks</TD></TR></TABLE>
yes, and with no exhaust you would make more still.
Old Jun 19, 2004 | 11:41 AM
espanol's Avatar
i made 489 on 19 psi w/ a greddy 2 3/4 exhaust.
Old Jun 19, 2004 | 11:43 AM
Default Re: How many of you have 450+hp with a 3" full exhaust (espanol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by espanol &raquo;</TD></TR><TR><TD CLASS="quote">i made 489 on 19 psi w/ a greddy 2 3/4 exhaust.</TD></TR></TABLE>
ahh.. good to know
Old Jun 19, 2004 | 12:24 PM
Boltz's Avatar
Default Re: How many of you have 450+hp with a 3" full exhaust (Turbo Chris)
I think SP engineering just started making 3.5" exhausts for civic and integras.
Old Jun 19, 2004 | 12:29 PM
JAY's Avatar
JAY
Default Re: How many of you have 450+hp with a 3" full exhaust (Boltz)
just run an open exhaust
Old Jun 19, 2004 | 02:18 PM
turbotypeR@SPEC's Avatar
25 Year Member
i made 534whp on 3" with 3 mufflers.a customer of mine made 443whp at 20 psi with 2.5"
Old Jun 19, 2004 | 04:37 PM
gritsak's Avatar
Default Re: How many of you have 450+hp with a 3" full exhaust (turbotypeR)
i made 644whp in my old supra with a 2.75" midpipe and the rest full 3"....3" will be plenty for most setups
Old Jun 19, 2004 | 06:35 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: How many of you have 450+hp with a 3" full exhaust (gritsak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gritsak &raquo;</TD></TR><TR><TD CLASS="quote">i made 644whp in my old supra with a 2.75" midpipe and the rest full 3"....3" will be plenty for most setups</TD></TR></TABLE>
I think that might end the discussion right there.
Old Jun 19, 2004 | 08:53 PM
PM-Performance's Avatar
Default Re: How many of you have 450+hp with a 3" full exhaust (rochesterricer)
3 inch is more then enuff for you, but if were on the topic of Supras i have witnessed Rados Supra do 788whp on a 3inch exhaust.
Old Jun 19, 2004 | 11:19 PM
Casey's Avatar
Default Re: How many of you have 450+hp with a 3" full exhaust (itr206)
but assuming bigger is better, a car making 400whp on a 3" will make more with a 3.5 correct
Old Jun 19, 2004 | 11:25 PM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">but assuming bigger is better, a car making 400whp on a 3" will make more with a 3.5 correct</TD></TR></TABLE>
The law of diminishing returns would probably begin to apply.
Old Jun 19, 2004 | 11:39 PM
Casey's Avatar
good point. factor in i can get the 3.5" for 210 shipped because its home made and not "pretty" but im sure it works well.
Old Jun 19, 2004 | 11:45 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Well then, I guess its up to you.
You might also want to consider that it may limit muffler selection, and I don't know if they make resonators that big. You may have to put up with a raspy exhaust note.
Old Jun 19, 2004 | 11:48 PM
Casey's Avatar
it has a dynamax muffler and a small resonator...there are tons of turbo diesel duallys running around with 4" mandrel exhaust and turbo honda in general arent what id call raspy. sounds not really an issue, just dont wanna hear open dp all the time
Old Jun 20, 2004 | 12:19 AM
ShaunRR's Avatar
HT White Ops
Community Builder
I suppose if you can get it for cheap then go for it.
Old Jun 20, 2004 | 02:49 AM
Weapon's Avatar
ok quick question then
how many of u are making 300+whp with a 2.5inch?
and whats ur setup :D
b18sihatch
Jun 2, 2006 06:04 AM
IntegraGSR311
Apr 16, 2005 05:30 PM
Sinner
Dec 24, 2003 06:11 PM
ezark
Mar 26, 2002 03:25 PM
JM Performance
Sep 27, 2001 01:14 PM
