Bogging type r
Old Jun 19, 2004 | 07:25 AM
Snail EK's Avatar
Default Bogging type r
I have a type R in a 92 cv hb and it bogs at around 4000rpm sounds like it hit a rev limiter and struggles to rev up to there any ideas or someone with similar problem?
Old Jun 19, 2004 | 07:26 AM
Mr Boston's Avatar
Default Re: Bogging type r (Snail EK)
Are you having a CEL (check engine light) on right now?
Old Jun 20, 2004 | 12:01 PM
itr1244's Avatar
Default Re: Bogging type r (Clicky Pow)
Old Jun 20, 2004 | 12:13 PM
knalige's Avatar
Default Re: Bogging type r (itr1244)
don't know if this will help but if you have a v-afc control in it....that could very well be your problem...i had the same problem...and it was because my wires were loose...
Old Jun 20, 2004 | 12:31 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snail EK &raquo;</TD></TR><TR><TD CLASS="quote">I have a type R in a 92 cv hb and it bogs at around 4000rpm sounds like it hit a rev limiter and struggles to rev up to there any ideas or someone with similar problem?</TD></TR></TABLE>
whats your ecu setup? are you running hondata by any chance.. it cuts fuel at 4K when unplugged.. otherwise, check/replace dist. rotor, plugs
Old Jun 20, 2004 | 01:47 PM
Slow_Em1's Avatar
Default Re: Bogging type r (vtec.dc2)
check under the distrubuter cap?...any corrosion or water?
also check spark plugs
remember: engines need 4 things to operate properly
1. fuel
2. compression
3. spark
4. air
check anyhtign that has to do with those things first then tell us what you come up with
flyinkman
May 1, 2013 07:09 PM
boush95ls
Apr 11, 2008 09:47 PM
SlowStockLude
10
Sep 8, 2005 09:12 AM
5thgen
12
Dec 5, 2003 06:12 PM
projek_civic
Sep 23, 2003 03:59 PM
