spark plugs wire for under 50 bux...where??
Old Jun 19, 2004 | 12:15 AM
BLUE EH3's Avatar
Help we my pennies
Default spark plugs wire for under 50 bux...where??
where can i get a nice set of spark plug wires for under 50 .. i cant find ****!
Old Jun 19, 2004 | 12:38 AM
hondaeg8's Avatar
Default Re: spark plugs wire for under 50 bux...where?? (BLUE EH3)
what kind of harness are you looking for? get some stock NGK wires.
Old Jun 19, 2004 | 12:40 AM
The Airman's Avatar
i believe autozone or pepboys will do the trick. if your talking about performance. you get what you pay for, to an extent.
Old Jun 19, 2004 | 12:43 AM
99blackcivicSi's Avatar
Default Re: spark plugs wire for under 50 bux...where?? (JMaxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMaxx &raquo;</TD></TR><TR><TD CLASS="quote">i believe autozone or pepboys will do the trick. if your talking about performance. you get what you pay for, to an extent.</TD></TR></TABLE>
uhhhh....no
OEM or NGK all i run in any honda
Old Jun 19, 2004 | 12:46 AM
NonovUrbizniz's Avatar
Loved
Default Re: spark plugs wire for under 50 bux...where?? (hondaeg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of harness are you looking for? get some stock NGK wires.</TD></TR></TABLE>
For most Sumitomo are stock wires... Not NGK...
I would recomend buying STOCK wires over any aftermarket ones... there have been a couple of wire tests that have shown the stock wires delivering more power than other wires including NGK...
Stock are the best and I believe they're around 13 bucks each from hondaautomotiveparts.com
Old Jun 19, 2004 | 01:42 AM
Turbo E's Avatar
cant go wrong with OEM, sides will you pay double or triple the $ for power you cant even feel?
Old Jun 19, 2004 | 02:53 AM
EK45VTi's Avatar
Default Re: (Turbo E 604)
As someone stated above, you will get the most of OEM wires...
Performance, durability, piece of mind - you name it!!!
Don't learn the hard way!!!
OEM all the way!!!
Old Jun 19, 2004 | 06:28 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (KKVTi)
are gsr,b16, itr, ls wires all the same?
Old Jun 19, 2004 | 08:43 PM
Two_K Si's Avatar
Default Re: (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">are gsr,b16, itr, ls wires all the same?</TD></TR></TABLE>
i believe so. http://www.sparkplugs.com has ngk wires for $51 and some change. Also, napa autoparts should be able to get ngk stuff.
Old Jun 19, 2004 | 10:21 PM
The Airman's Avatar
Default Re: spark plugs wire for under 50 bux...where?? (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">
uhhhh....no
OEM or NGK all i run in any honda</TD></TR></TABLE>
i was just saying they work, and making a point. he didn't specify any preference. and hondas aren't that special But i agree with you.
Old Jun 19, 2004 | 10:24 PM
dogfood's Avatar
don't go cheap on stuff like that, oem and ngk is the way to go
Old Jun 19, 2004 | 10:26 PM
Deemeetree's Avatar
Electrician
OEM Honda wires.
stock99si
May 14, 2007 06:43 PM
Jaydeep
14
Aug 17, 2004 10:24 PM
Rene M
May 9, 2004 05:29 PM
B_1_8_hatch
Oct 13, 2003 10:52 AM
Mr. TopFuel
Sep 11, 2003 07:03 PM
