will cause header wrap cracking....?
Old Jun 19, 2004 | 12:02 AM
BLUE EH3's Avatar
Help we my pennies
Default will cause header wrap cracking....?
if you wrap your headers , will your headers crack or become ruined
yes or no
Old Jun 19, 2004 | 12:04 AM
SiRacerSC's Avatar
Default Re: will cause header wrap cracking....? (BLUE EH3)
don't wrap, only because it looks bad, it won't cause crack, guy.
Old Jun 19, 2004 | 01:45 AM
Turbo E's Avatar
Default Re: will cause header wrap cracking....? (SiRacerSC)
will it crack? maybe. extreme heat does wonders
will it rust out faster? definately. water gets held in the fibres
will it keep your engine bay cooler? yup. heat stays in the exhaust = faster exh flow = power
will it help performance? yup. cooler intake temps = mo power
is it ugly? thats subjective.
should you listen to noobs? the jury is out on that one
Old Jun 19, 2004 | 06:08 AM
Boostage's Avatar
Default Re: will cause header wrap cracking....? (Turbo E 604)
wont crack if you mani is made of cast stainless steel
Old Jun 19, 2004 | 06:30 AM
Padawan's Avatar
Darth ModerVader
Default Re: will cause header wrap cracking....? (Boostage)
It will still trap excessive heat within the metal, which isn't good for longevity.
Your best bet for reducing under-hood temps, protecting the header, and for performance benefits would be to have the header professionally coated (inside and out) with a metallic-ceramic coating.
moomakudafi's Avatar
had some on my dodge truck and it caused some major rusting and some cracks on the actual header. the underhood temps went down a lot though. its a good thing to have but takes away the life of the header. unless you got money later on down the road to buy a new set, i wouldnt do it. just my $0.02 for ya.
Old Jun 19, 2004 | 06:26 PM
BLUE EH3's Avatar
Help we my pennies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">wont crack if you mani is made of cast stainless steel</TD></TR></TABLE> it is stainless steel!!
Old Jun 20, 2004 | 12:19 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote"> it is stainless steel!!</TD></TR></TABLE>
You'll still be better off either leaving it unwrapped, or having it professionally coated.
Old Jun 20, 2004 | 01:50 PM
fishnfst's Avatar
I'd like to see your cast stainless steel header....
Old Jun 20, 2004 | 02:01 PM
ej1 pilot's Avatar
Default Re: (fishnfst)
you typed your title backwards
Old Jun 20, 2004 | 02:29 PM
Boostage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst &raquo;</TD></TR><TR><TD CLASS="quote">I'd like to see your cast stainless steel header....</TD></TR></TABLE>
I have the sfp cast ss heaader
Old Jun 20, 2004 | 04:11 PM
North_Texas's Avatar
Default Re: (Boostage)
WOW this already been discussed not even a week ago.
gamesteraj
May 13, 2010 10:20 AM
soopafly828
Apr 30, 2003 03:48 PM
Lo-Buck EF
26
Sep 5, 2002 01:26 PM
garagespecial
Jun 22, 2002 11:24 AM
Blue Liquid
Mar 14, 2002 04:11 AM
