need help installing speaker for dx civic
Old Jun 18, 2004 | 08:46 PM
jdl3000's Avatar
Default need help installing speaker for dx civic
I need help Installing rear speaker for a 90 civic dx hatch back.
the car did not have any rear speakers only front speakers.
I want to know which wire to put directly to the rear.
Old Jun 21, 2004 | 12:34 AM
MCall's Avatar
Default Re: need help installing speaker for dx civic (jdl3000)
uhm
if its an aftermarket head unit, check the manual
Old Jun 22, 2004 | 01:33 AM
IMMORTAL-B18's Avatar
I remember in my 95 Civic Hatch that there was wire ran and left sitting behing the paneling back in the back seat. You may want to check around to see if the wire was ran, but never used. Could be an easy solution to your problem.
Old Jun 22, 2004 | 07:03 AM
fcm's Avatar
fcm
Old Fart
All Hondas have all 4 speaker wire sets run, look around the OEM speaker locations for the wires
I'm not sure but I think your 95 came with a dummy cover over rear speaker locations just above the left and right rear seat armrest spots.
You would have to replace the covers with the grilled ones, and add the speaker mounts if you want to place speakers in the OEM locations.
hope this helps. 94
Old Jun 24, 2004 | 08:59 PM
jdl3000's Avatar
found those 4 wires
vitrox in civic crx forum gave me the wiring diagram
check my wires behind my stock radio and it was just sitting there unconnected
thanks for your response
Old Jul 18, 2004 | 12:35 AM
Paprika's Avatar
I have a 92' Civic, would the same diagram work for me? if so could you hit me up on AIM: MansfieldSenior or email KamronDTS[at]neo.rr.com
Old Jul 19, 2004 | 10:51 AM
fcm's Avatar
fcm
Old Fart
Default Re: need help installing speaker for dx civic (Paprika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paprika &raquo;</TD></TR><TR><TD CLASS="quote">I have a 92' Civic, would the same diagram work for me? if so could you hit me up on AIM: MansfieldSenior or email KamronDTS[at]neo.rr.com</TD></TR></TABLE>
http://www.installdr.com 94
Old Jul 22, 2004 | 10:40 PM
Paprika's Avatar
Default Re: need help installing speaker for dx civic (fcm)
Unfortunately they don't have the diagram and information on installing speakers into the civic though they have it for installing the radio.
Old Jul 23, 2004 | 05:57 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paprika &raquo;</TD></TR><TR><TD CLASS="quote">Unfortunately they don't have the diagram and information on installing speakers into the civic though they have it for installing the radio.</TD></TR></TABLE>The speaker wire in the 92 civic will also be at the stock speaker locations for that car, you will also need grills and mounts if it did not come with speakers for the rear, the wire color is the same as it is at the HU. 94
Old Jul 23, 2004 | 12:51 PM
Paprika's Avatar
Yeah lol, the wires /are/ there and all that good stuff. I just don't have the mounts or the grills and thats my only real downfall right now. I just need to get ahold of them or find another solution.
Old Jul 23, 2004 | 05:42 PM
fcm's Avatar
fcm
Old Fart
A trip to the bone yard should fix that. or there is always the wonder of MDF. 94
Old Jul 25, 2004 | 10:42 PM
Paprika's Avatar
I plan to start doing the junkyard thing for the grills tommorow, but are there any other places (online or whever) that I could aquire atleast the tan grills for the rear deck? Cause the speakers don't need the cages to be mounted, I figured this out earlier today.. one would drop them in the holes from above rather than puting them in the cage from below.
Old Jul 26, 2004 | 07:34 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paprika &raquo;</TD></TR><TR><TD CLASS="quote">I plan to start doing the junkyard thing for the grills tommorow, but are there any other places (online or whever) that I could aquire atleast the tan grills for the rear deck? Cause the speakers don't need the cages to be mounted, I figured this out earlier today.. one would drop them in the holes from above rather than puting them in the cage from below.</TD></TR></TABLE> Your 92 is not a hatch? if not, then /i think the speakers may mount to the grills, and the grills, and you may be able to get them from metra link http://www.metra.com
94
Old Jul 26, 2004 | 10:38 AM
Paprika's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Your 92 is not a hatch? if not, then /i think the speakers may mount to the grills, and the grills, and you may be able to get them from metra link http://www.metra.com
94 </TD></TR></TABLE>
No it's not a hatch. It's a 4dr Sedan. The speakers can mount right onto the frame, and as far as the grills I might just use the ones that came w/ the speaker.. Since they'll all be the same size and I won't be changing speaker sizes anytime soon it should be ok. I was told by someone else it would work out fine, plus lol I don't think I want to do the junkyard thing anymore.
Moreover, that Metra site didn't work.
bubbenboy_90
Apr 7, 2015 12:25 PM
lPat
Audio / Security / Video
Aug 2, 2007 08:16 PM
BogusMalone
Jun 28, 2006 06:29 PM
tecmand
20
May 23, 2006 08:03 PM
hothatch
May 20, 2001 08:02 AM
