speaker wiring help
Old Aug 1, 2007 | 09:08 PM
lPat's Avatar
Default speaker wiring help
i just bought a 93 civic si hatch (eg)
i was wondering if they came with rear speakers because i dont have any in mine
and if not then how would i run some back speakers???
Old Aug 2, 2007 | 04:28 AM
B18C_EJ8's Avatar
Alot of early 90's Honda's didn't come with rear speakers.
However, they were all wired for rear speakers. The harness is there if you pull the grille/panel/blockoff plate.
Old Aug 2, 2007 | 09:54 AM
lPat's Avatar
Default Re: (B18C_EJ8)
can you post a pic of where it is so i dont try to run a speaker to the wrong wire
Old Aug 2, 2007 | 12:02 PM
suspendedHatch's Avatar
Default Re: (lPat)
It will be fairly obvious. It's the only plug connector in the empty speaker hole not connected to anything.
Wire colors should be
RR+ red/yellow
RR- brown/white
LR+ blue/yellow
LR- gray/white
Although some of the cars (ie 90 Si) colors will vary. The front and rear speaker wire colors will be jumbled. In fact I don't think there were any rear speaker wires back there at all. But I sold that car so...
Old Aug 2, 2007 | 03:48 PM
lPat's Avatar
Default Re: (suspendedHatch)
my car didnt have speaker holes or anything for the rear only the front i see in other poeples hatches they have made holes in the cargo cover to put speakers in but i dont see where they find the speaker wire at for the rears
Old Aug 2, 2007 | 04:17 PM
B18C_EJ8's Avatar
There are panels covering the are where the grilles would be. They're located in the panels on either side of the back seat.
Old Aug 2, 2007 | 06:35 PM
fcm's Avatar
fcm
Old Fart
Default Re: (lPat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lPat &raquo;</TD></TR><TR><TD CLASS="quote">my car didnt have speaker holes or anything for the rear only the front i see in other poeples hatches they have made holes in the cargo cover to put speakers in but i dont see where they find the speaker wire at for the rears</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">There are panels covering the are where the grilles would be. They're located in the panels on either side of the back seat.</TD></TR></TABLE>
What he said^^^
The speaker leads are there, all the way down to the bottom, on the floor pan, the plug will be taped to the rear harness running down the drivers side of the car, on the pass. side the speaker lead is folded in 1/2 and the plug is taped to the speaker lead itself and laying at the bottom on the floor pan.
There will be no speaker mounting bracket behind the "dummy grill", [blank trim panel covering speaker hole/location], you can probably Google a set up, or make your own, to do properly for a set of 6.5" full-range drivers, lots of work, 6 - 8 hours for a set of mid-range/mid-bass drivers, way more work, 10 - 15 hours over 2 days.
Oh yea, stock brackets 3 - 5 hours.
Also, the rear security cover, [cargo cover] should not be an option for speakers, mounting speakers to it is just barely better then just putting them on the rear set.
If nobody has said it yet, [I started the post 2 hr. ago] Better bet would be to concentrate on front speakers, the TEC result ratio is way better. 94
Old Aug 2, 2007 | 08:16 PM
lPat's Avatar
Default Re: (fcm)
thanks for all the help i will check it out tommorw morning.
stinkypinky1011
Sep 27, 2013 04:19 AM
01cwtyper
Audio / Security / Video
Dec 31, 2012 02:56 PM
hondaon18's
Jul 28, 2007 11:34 AM
USDM-EK4*
Feb 14, 2007 03:08 PM
icucnme
Oct 28, 2005 02:54 PM
