coil sleeve coilover please help
Old Jun 18, 2004 | 01:13 PM
hatchback_al's Avatar
Default coil sleeve coilover please help
i bought some cheap-o coil sleeve "coilovers" to go on my kyb gr2 struts. 2 questions, how the hell do they go together and how do i know which one is for which corner. 2 springs have 350 rates and 2 have 450. a bag of 20 or so little o-rings and a bag of allen wrenches and 2 different sized set screws were included, where do these go? any help appreciated.
Old Jun 18, 2004 | 01:23 PM
Targa250R's Avatar
be professional
Default Re: coil sleeve coilover please help (hatchback_al)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback_al &raquo;</TD></TR><TR><TD CLASS="quote">kyb gr2 struts . . . 2 springs have 350 rates and 2 have 450</TD></TR></TABLE>
Uh oh . . .
Old Jun 18, 2004 | 01:26 PM
1slow_si's Avatar
I would assume the higher spring rates are for the rear. That's about all I can tell you without pics.
Old Jun 18, 2004 | 03:55 PM
Tyson's Avatar
http://www.norcalcrx.org/tyson/coilover.html#09
Which springs go up front?
First, learn how to read the spring rate from your springs. One pair will be stiffer (greater spring rate) than the other. GC normally designs their spring kits so that the front is stiffer. You can follow that, but ERS(springs) are interchangeable. So you CAN put the stiffer in the rear, it will alter the suspension by basically making the rear stiffer, which makes the car less understeer, which is generally more desirable for better handling performance. However, it *makes the rear stiffer*, and you will feel the difference since FWD cars have the center of gravity more towards the front, so the rear wheels rotate further from the CG than the fronts, thus are more sensitive to bouncing motion. Its up to you. I suggest you just follow what GC recommends, but if you are so inclined, cautiously try to swap them and see what you prefer.
Old Jun 18, 2004 | 06:52 PM
CaptainGSR's Avatar
Default Re: coil sleeve coilover please help (Tyson)
what are all the little set screws for and the bag of o rings has 3 different sizes, 8 of each...
Old Jun 18, 2004 | 06:54 PM
Targa250R's Avatar
be professional
Default Re: coil sleeve coilover please help (CaptainGSR)
https://honda-tech.com/zerothread?id=887532
This may help you.
So would the instructions.
Old Jun 18, 2004 | 08:35 PM
hondaboyz91si's Avatar
the long ones go in the rear an the little ones go in the front
Old Jun 19, 2004 | 12:11 AM
Default Re: coil sleeve coilover please help (hondaboyz91si)
my coilovers came with no instructions, what are all the little set screws for? i cant figure it out!
Old Jun 19, 2004 | 08:55 AM
anyone? i want to put these in tonight
Old Jun 19, 2004 | 09:39 AM
bump before work
Old Jun 19, 2004 | 01:18 PM
green91's Avatar
the rings go between the shock and the coil-over sleeve. just put them on as you see fit.. with cheapos they usually dont do **** anyway.
Old Jun 19, 2004 | 03:14 PM
CaptainGSR's Avatar
Default Re: (green91)
what about all these little set screws?
Old Jun 20, 2004 | 05:32 PM
splinter51's Avatar
Default Re: (CaptainGSR)
they center the sleeve duh...
Emerica
Suspension & Brakes
Oct 11, 2007 10:52 AM
ware
Suspension & Brakes
14
Aug 23, 2007 05:49 PM
bmoua
Jul 22, 2007 05:24 PM
jonGSR
Mar 7, 2004 10:11 PM
silvraccord99
Feb 10, 2004 10:26 PM
