JDM H22A into 2000 Honda Prelude
How can I make this work using the OBDII wiring harness?
From the searches I have done, it looks like you have to change the ECU, wiring for distributor, and some sensors.
Can someone please help me out.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95deckedlude »</TD></TR><TR><TD CLASS="quote">that car comes with an h22
whats the point?</TD></TR></TABLE>
Higher compression.
If using your stock ecu and injectors, I believe you will need to use your OBDII distributor, and CYP and CKP sensors. Not sure if your stock ecu and injectors will be sufficient for the higher compression, but a fuel pressure regulator should take care of that.
Higher compression.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Euro-R »</TD></TR><TR><TD CLASS="quote">Why buy a whole motor when you can get type-S pistons and drop them in. 11:1 comp is nice.</TD></TR></TABLE>
thats what i meant. no point in buying a whole motor
