getting tranny snap-ring to snap in place -------------------------------------
Old Jun 17, 2004 | 06:50 PM
Del_Slowest's Avatar
Default getting tranny snap-ring to snap in place -------------------------------------
how in the world do i get it to snap back into place. the case can be bolted almost all the way down. i use my snap pliers to spread it and then i have gramps turn the tranny upside down and we hit it with the hammer to get the shaft to fall. well it won't fall. then we try letting it drop on the floor a few times and it still won't fall. Does anybody have any ideas? how do you guys do it. btw- this is for a b16 ys1 hydro tranny, not like it matters much
Old Jun 17, 2004 | 07:03 PM
2FastxEg's Avatar
same damn problem for me.
Old Jun 17, 2004 | 07:05 PM
mmuller's Avatar
Mad Scientist
Default Re: getting tranny snap-ring to snap in place ------------------------------------- (Del_Slowest)
turn it around and drop it (lightly) on a 2x4 , voila
Old Jun 17, 2004 | 07:19 PM
Default Re: getting tranny snap-ring to snap in place ------------------------------------- (mmuller)
do i put some bolts in the housings? we have 4 in there right now, they're snug but not tight. we also tried loosening them more but it doesn't change anything. we were dropping it on the concrete floor from about 4 inches. how high should i drop in on the wood? and should i have any bolts in it when i do it?
Old Jun 17, 2004 | 07:20 PM
could anything inside the tranny be hanging it up? we put my clutch on and were able to rotate the main shaft many turns. we also tried shifting it a lil but i'm not really good at knowing what gear i'm in when i pull the shifter in and out.
Old Jun 17, 2004 | 07:27 PM
mmuller's Avatar
Mad Scientist
is the snap ring in and just not seated or just not on at all?
Old Jun 17, 2004 | 07:29 PM
its a snap ring width away from being in the groove
Old Jun 17, 2004 | 07:39 PM
mmuller's Avatar
Mad Scientist
i dunno, dropping usually works for me...i say a 2x4 so that you dont drop the tranny on the concrete.
Old Jun 17, 2004 | 07:51 PM
i think i found my answer. i may have a burr in there like this guy did. it's the EXACT same problem i am having so i'm crossing my fingers
https://honda-tech.com/zero...24504
Old Jun 19, 2004 | 11:45 PM
i was missing the washers that go on the bottom of the input shaft. that was the whole problem
Old Jun 25, 2004 | 08:12 AM
PnX-R's Avatar
Yep, usually when it doesn't want to go, something's either missing or not lining up..
blakacintegra
Jul 15, 2007 11:22 PM
WGFletch4WS
May 30, 2007 11:08 AM
triggerX
Apr 24, 2004 12:03 AM
spladam02
Dec 9, 2002 06:05 AM
