Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
WCHC Rules-----Dashboard Intact?
Old Jun 17, 2004 | 12:09 PM
FormulaIntegra's Avatar
Default WCHC Rules-----Dashboard Intact?
Quick interpretation question of the rules. I believe the HC rules say the dashboard must remain intact.... does this mean I can gut all of the air/gauge/radio/glove compartment stuff, as long as the shell of the dash remains intact? How much has to remain? I want to install an aluminum panel where the passenger airbag used to be, and I don't know if its allowed or not. Thanks, bro's.
Old Jun 17, 2004 | 12:12 PM
buckNasty's Avatar
Default Re: WCHC Rules-----Dashboard Intact? (FormulaIntegra)
yeah im interested too, i was thinking of replacing my dash with a cf one
Old Jun 17, 2004 | 12:41 PM
D.CACO's Avatar
Default Re: WCHC Rules-----Dashboard Intact? (bucbaby)
The Only part of the dash that we have in our EK is the dash itself and the guage cluster. meaing no glove box, no center console, no vents, no heater core, no cupholders, no airbags, etc... I think* you should be able to cover the passenger side airbag with aluminum plate...our center console is covered with a CF plate.
bucbaby- for HC, I dont think you can use a CF dash.
Old Jun 17, 2004 | 12:43 PM
emwavey's Avatar
Default Re: WCHC Rules-----Dashboard Intact? (D.CACO)
If this parallels SCCA rules, I'm fairly certain the front down tubes of a roll cage can go through holes cut in the dash. Yeah?
Old Jun 17, 2004 | 12:46 PM
Footwork's Avatar
Default Re: WCHC Rules-----Dashboard Intact? (emwavey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emwavey &raquo;</TD></TR><TR><TD CLASS="quote">If this parallels SCCA rules, I'm fairly certain the front down tubes of a roll cage can go through holes cut in the dash. Yeah?</TD></TR></TABLE>
oem dash yes.
Old Jun 17, 2004 | 12:54 PM
SPiFF's Avatar
Default Re: WCHC Rules-----Dashboard Intact? (Primo.)
Like others have said. No CF, dash modified for roll cage clearance only.
Old Jun 17, 2004 | 01:27 PM
Crack Monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D.CACO &raquo;</TD></TR><TR><TD CLASS="quote">The Only part of the dash that we have in our EK is the dash itself and the guage cluster. meaing no glove box, no center console, no vents, no heater core, no cupholders, no airbags, etc... I think* you should be able to cover the passenger side airbag with aluminum plate...our center console is covered with a CF plate.</TD></TR></TABLE>
What he said.
Note that this is beyond what the SCCA allows for IT, so if you are building a dual-use car, be sure to read both the GCR and NASA CCR/HC rules.
Old Jun 17, 2004 | 02:32 PM
Default Re: WCHC Rules-----Dashboard Intact? (Crack Monkey)
Anyone got a GCR handy for the SCCA ruling on this one? I'm out of state, working on the car, and forgot mine at home.
Old Jun 17, 2004 | 02:36 PM
D.CACO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FormulaIntegra &raquo;</TD></TR><TR><TD CLASS="quote">Anyone got a GCR handy for the SCCA ruling on this one? I'm out of state, working on the car, and forgot mine at home. </TD></TR></TABLE>
Working on the car "out-of-state"? Hmmm.... enquiring minds want to know.
Old Jun 17, 2004 | 03:23 PM
Ha ha ha....that's my secret, to be unveiled at my debut race....(someday, sigh)
Actually, my brother-in-law is an ASE master certified automotive tech in Phoenix (which is why he's my head mechanic. He's got way cooler tools than I do.)
Old Jun 17, 2004 | 04:10 PM
Racerboy03's Avatar
Heater Core must remain intact for SCCA IT classes.(I have no idea why..) Other then that you can modify the dash for the roll cage. You should be able to put that gauge panel in no problem.
-Mark
Old Jun 17, 2004 | 05:01 PM
KIWI's Avatar
My interpretation is that the OEM Dash cover/ shell call it what you will must remain in place. I t can be modified to allow for the roll cage bars.You can gut everything out of it and fill all the holes where the Gauges, A/C, Heater, switches, Vents etc were with alloy sheet or whatever you like. And you can replace all gauges, and switches if you want.
Thats what we've done???
I hope were not opening another can of worms here?
Old Jun 17, 2004 | 05:05 PM
KIWI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D.CACO &raquo;</TD></TR><TR><TD CLASS="quote">...our center console is covered with a CF plate.</TD></TR></TABLE>
Oh **** no Dennis!!!! A CF Console plate!!!!? No No No you'll ruin the series man!
Kiwi
Old Jun 17, 2004 | 07:50 PM
myke's Avatar
From: South LA...107th and fig to be exact...for the foo
Default Re: WCHC Rules-----Dashboard Intact? (KIWI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KIWI &raquo;</TD></TR><TR><TD CLASS="quote">
Kiwi</TD></TR></TABLE>
isnt your front splitter made out of plywood?
Old Jun 18, 2004 | 09:42 AM
Default Re: WCHC Rules-----Dashboard Intact? (myke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by myke &raquo;</TD></TR><TR><TD CLASS="quote">
isnt your front splitter made out of plywood?</TD></TR></TABLE>
HA HA HA HA HA!!! It is when it's not splintered all over Willow Springs!!!
Old Jun 18, 2004 | 10:03 AM
Don't have it here, but I know the heater/AC controls have to remain, heater core remains, wiring behind dash remains. Stereo can be yanked and dash can be cut to make room for cage, that's about it. You can install any gauges you want, in stereo hole or in front of stock gagues. Steering column combo seitches have to remain as well, AFAIK.
Old Jun 18, 2004 | 10:08 AM
KIWI's Avatar
Yep... It might be made out of Plywood.
But it's still the Cheapest, easiest, and right now the most efective out there.
I've tried every type of composite, Carbon fiber, Aluminum, Unobtatianium, Fiberglass... You name it ! A splitter should be considered as a disposable item.
The thing that all of the above have in common... They fly to pieces when they hit an immovable object! I have found that Plywood coated with fiberglass cloth will last and will slide over most curbs etc. with slight splintering and scuffing and if it's good enough for F1 it's good enough for me. Sorry for Hijacking the thread.
Kiwi
Old Jun 18, 2004 | 01:17 PM
D.CACO's Avatar
We saved a whole 0.3668 lbs using CF, but now incur a 50 lb. weight penalty as a result.
kwiatu
Jan 11, 2016 08:53 AM
spoonInspired
Jul 29, 2005 06:53 AM
apexinghonda
Jan 7, 2005 05:05 AM
9krpm
May 4, 2003 03:31 PM
