Fuel Injectors
Old Jun 17, 2004 | 08:36 AM
h22_civ's Avatar
Default Fuel Injectors
Why does the 92-96 prelude require peak and hold fuel injectors when all the other acuras/hondas later than 92 use saturated?? Is it because of the resistance levels or some other reason??
Old Jun 17, 2004 | 08:59 AM
graphic's Avatar
Default Re: Fuel Injectors (h22_civ)
i believe that the peak and hold injectors are low impedence (ohm's)
and the saturated injectors are high impedence (ohm's)
the peak and hold would require the resistor box
Modified by graphic at 6:23 PM 6/17/2004
Modified by graphic at 6:26 PM 6/17/2004
Old Jun 17, 2004 | 09:19 AM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22_civ &raquo;</TD></TR><TR><TD CLASS="quote">Why does the 92-96 prelude require peak and hold fuel injectors when all the other acuras/hondas later than 92 use saturated?? Is it because of the resistance levels or some other reason??</TD></TR></TABLE>
yes the resistance levels are different , all honda ecus expect to see a higher load on the driver circuit for the injectors, some just run strait saturated whihc are already high impedence or honda used peak and hold for cost/performance? difference and they are lower resistance so they added the resistor pack on so the resistance level will be correct on the drie circuit for the injectors.
JDM-JAMES
Feb 18, 2009 06:57 PM
uncledan
Aug 21, 2008 07:46 AM
Sleeper Sii
Mar 27, 2002 10:18 PM
H23 Power
Feb 25, 2002 02:56 PM
VaporTrail
Feb 11, 2002 09:23 PM
