Sohc VTEC question!
Old Jun 16, 2004 | 09:38 PM
jdmef9_2nr's Avatar
Default Sohc VTEC question!
I swapped a 95 Si head with the vtec solenoid on it into my little d15b2 motor...
i was wondering how i would get started in order to get the vtec working...i dont have the multi-port fuel injection intake manifold...but is that necessary for the vtec to function?...or is it possible to use my dual-point intake manifold?...i would really appreciate opinions and ideas...thanks!
http://members.cardomain.com/jesterxiong <-- check out my ride!
Old Jun 16, 2004 | 09:47 PM
HumanResource's Avatar
Default Re: Sohc VTEC question! (jdmef9_2nr)
While it IS possible to run the SOHC VTEC head with the stock DPFI, it's HIGHLY not recommended. Increased INT. Cam Duration of VTEC requires additional Air & Fuel which the DPFI set-up is far from efficient at providing
Save yourself the trouble and get some MPFI parts
Old Jun 16, 2004 | 09:57 PM
johnclaunch's Avatar
Did you have the bumpers painted or was it already like that? Where did you get the full amber corners?
Old Jun 17, 2004 | 02:42 PM
jdmef9_2nr's Avatar
Default Re: Sohc VTEC question! (johnclaunch)
I actually painted the bumpers myself...with spray paint..haha...how does it look huh? not bad for spray paint? well, this summer im gonna get a real paint job...i dont exactly know what color yet...still deciding...i got the amber corners off ebay...it wasnt cheap...$40...
Old Jun 17, 2004 | 05:23 PM
90efcrx's Avatar
will hlep u out
https://honda-tech.com/zerothread?id=639552
https://honda-tech.com/zerothread?id=635580
Old Jun 17, 2004 | 05:31 PM
90efcrx's Avatar
Default Re: Sohc VTEC question! (90efcrx)
DAMN one clean *** hatch dude
Old Jun 17, 2004 | 06:59 PM
-slow ej-'s Avatar
i have a 88 si iintake manifold for you if you need it...let me knno...ill let it go for cheap too = )
Old Jun 17, 2004 | 07:27 PM
jdmef9_2nr's Avatar
Default Re: Sohc VTEC question! (-RsINtEg-)
Hmmm...well, i've thought about it...but then i decided to just run the motor until i swap a b series motor...i messed around with the stock motor too much already... im experiencing misfires and hard idling...so i think i'll just stick to what i have...but tell me the price anyways..i might reconsider...thanks!
Old Jun 17, 2004 | 07:38 PM
green91's Avatar
unless you have serious head/block damage id be willing to bet that in the parts you swap out doing the mpfi you will fix your problems also! mpfi alone makes a huge difference.. another 20 hp or so on top of mpfi would be very nice.. especially since your not very far from it!
sohcvtec97
Oct 3, 2005 12:37 AM
FaceTuned
Aug 8, 2005 10:35 AM
redINTEGRAdriver
Mar 12, 2005 02:21 AM
G3NR8
25
Apr 23, 2003 09:28 AM
91ReXSI
Dec 9, 2001 06:51 PM
