Which LSD for YS1 Tranny?
Old Jun 16, 2004 | 06:39 PM
CWESTINAP1's Avatar
Default Which LSD for YS1 Tranny?
which application should i get the lsd for? at 80mph my rpm is around 5k. quaife or kaaz? i heard ctr/itr lsd's also will fit, is this true?
Old Jun 16, 2004 | 07:05 PM
michael O's Avatar
Default Re: Which LSD for YS1 Tranny? (CWESTINDC2)
I have the same tranny and I got a quaife. Seems to be working great so far. Haven't tried ctr or itr or kaaz so I dunno about them.
Old Jun 16, 2004 | 07:30 PM
1's Avatar
Default Re: Which LSD for YS1 Tranny? (michaelOlson)
ITR/CTR LSDs can fit but the inside of the case must be ground out a bit. Also, you need to use the ring gear that comes with said LSD.
Old Jun 16, 2004 | 10:28 PM
CWESTINAP1's Avatar
Default Re: Which LSD for YS1 Tranny? (1)
what do mean by the case must be ground out a bit?
Old Jun 16, 2004 | 11:09 PM
spooncvc's Avatar
the hole is a little smaller than the LSD...you might need to grind the casing a little to make it fit
Old Jun 17, 2004 | 12:57 AM
CWESTINAP1's Avatar
Default Re: Which LSD for YS1 Tranny? (spooncvc)
thanks for the info, i was also wondering if all ys1 synchros are the same? and what clutch will fit the ys1 tranny? gsr/type r clutches?
Old Jun 17, 2004 | 03:33 AM
EFSiR's Avatar
I'm runnning ITR flywheel with CM ITR setup so yes, ITR and GSR all years will fit.
Old Jun 17, 2004 | 04:37 AM
Davep's Avatar
It's very easy to do, you just have to grid two small spots in the case for the diff to fit in.
Old Jun 18, 2004 | 07:01 AM
owen_the_soyboy's Avatar
Default Re: Which LSD for YS1 Tranny? (Davep)
what he said.
I dropped an ITR LSD into my B17 YS1 tranny by using a Hydro GSR ring gear, thats the same as U.S. ITR ring gear... its a 4.4:1 gear.
you only need to grind 1/8" off of a few of the wings/webs/casting protrusions in the area of the differential, its easy... like 5 minutes with a Dremel, you could even do it with a small hand file, the aluminum is easy to remove.
Old Jun 20, 2004 | 10:29 PM
CWESTINAP1's Avatar
Default Re: Which LSD for YS1 Tranny? (owen_the_soyboy)
just wondering, what other gears can fit in this tranny? ITR Gears? GSR gears? thanks for the help guys.
Old Jun 21, 2004 | 04:16 AM
the BIG Spline YS1 cable trannies will accept the entire gearset (or portions of it) from ITRs and GSR's.
This also includes synchros... cool huh!
Old Jun 21, 2004 | 01:16 PM
CWESTINAP1's Avatar
whats the difference between the big spline ys1 and the regular spine ys1? and how do you tell if you have the big spline ys1? also are gsr synchros, and itr synchros the same?
Old Jun 21, 2004 | 02:02 PM
5litereater's Avatar
pretty sure all ys1's have the big spline? i may be wrong but mine is big.
Old Jun 21, 2004 | 02:26 PM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWESTINDC2 &raquo;</TD></TR><TR><TD CLASS="quote">whats the difference between the big spline ys1 and the regular spine ys1? and how do you tell if you have the big spline ys1? also are gsr synchros, and itr synchros the same?</TD></TR></TABLE>
Its a fact, all 92-93 gsr YS1 tranny's are the big spline style.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy &raquo;</TD></TR><TR><TD CLASS="quote">the BIG Spline YS1 cable trannies will accept the entire gearset (or portions of it) from ITRs and GSR's.
This also includes synchros... cool huh!</TD></TR></TABLE>
Gears 2,3 and 4 are the same as the ITR
Old Jun 21, 2004 | 10:58 PM
CWESTINAP1's Avatar
Default Re: Which LSD for YS1 Tranny? (Deetz)
thanks for the details guys, anyone know a good place to buy synchros?
Old Jun 22, 2004 | 06:00 AM
BERT-O on this board, he's at Gettel Acura in Florida.
I used '99-'00 Si synchros to repair my B17 YS1 tranny, worked like a charm.
Old Jun 22, 2004 | 09:44 AM
spaceman's Avatar
sorry for using your thread but its on topic..could i use an itr lsd for my jdm s1 tranny?...what do i need?...what year itr will work best?
Old Jun 22, 2004 | 02:18 PM
CWESTINAP1's Avatar
how much were those synchros? or the rebuild kit?
Old Jun 23, 2004 | 05:11 AM
Default Re: Which LSD for YS1 Tranny? (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">sorry for using your thread but its on topic..could i use an itr lsd for my jdm s1 tranny?...what do i need?...what year itr will work best?</TD></TR></TABLE>dont think so....
sirminder
Sep 5, 2003 11:34 AM
cock head
Sep 16, 2002 04:53 AM
88crxoncrack
Jun 15, 2002 11:14 AM
