knock sensor grounded = no cel?
Old Jun 16, 2004 | 06:31 PM
lsvtec101's Avatar
Default knock sensor grounded = no cel?
how do i ground the knock sensor out? will this give me no cel?
Old Jun 17, 2004 | 05:22 AM
lsvtec101's Avatar
anybody?
Old Jun 17, 2004 | 05:57 AM
civicgsr's Avatar
Default Re: (lsvtec 02917)
The block is the ground. That is why there is only one wire coming out of it.
Alex
Old Jun 17, 2004 | 06:27 AM
lsvtec101's Avatar
Default Re: (civicgsr)
would i ground the wire on the wiring harness that goes to the knock sensor and that would give me no cel?
Old Jun 17, 2004 | 07:54 AM
mmuller's Avatar
Mad Scientist
Default Re: (lsvtec101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec101 &raquo;</TD></TR><TR><TD CLASS="quote">would i ground the wire on the wiring harness that goes to the knock sensor and that would give me no cel?</TD></TR></TABLE>
no, you'll still get a cel.
you could if your sensor is good, take it out of the block and ground it somewhere else ; leave it plugged in.
Old Jun 17, 2004 | 08:09 AM
lsvtec101's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
what could i ground it to? do i have to screw the ks into something?
Old Jun 17, 2004 | 08:10 AM
civicgsr's Avatar
No, the wire that comes out of the sensor goes to the ECU. The sensor is probably bad if you are getting a code. You probably need to check the continuity of the wire to make sure the signal is getting back to the ECU. Again, the sensor is grounded through the block, meaning there is no extra grounding necessary.
As mmuller pointed out, you can pull the sensor and ground it somewhere else. I would try to resolve the problem before you use a solution like that.
-Alex
Old Jun 17, 2004 | 08:14 AM
lsvtec101's Avatar
its a B18B block it has no ks. im getting my car inspected and im running obd2 so i was wondering if i could get away with grounding it to something else so i wouldnt get a CEL.
Old Jun 17, 2004 | 08:24 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec101 &raquo;</TD></TR><TR><TD CLASS="quote">its a B18B block it has no ks. im getting my car inspected and im running obd2 so i was wondering if i could get away with grounding it to something else so i wouldnt get a CEL.</TD></TR></TABLE>
yeah you could do what i sayd above or you can tap where the bolt for the alternator bracket goes and put the ks there
Old Jun 17, 2004 | 10:22 AM
Honda Sport's Avatar
kinda OT but on OBD-1, is it D3 that it goes to? same with OBD-II??
mustninty20
Dec 19, 2008 03:36 PM
Powered By Garrett
Mar 30, 2008 12:05 PM
Phatch99
12
Jul 22, 2004 03:08 PM
PhatHardy
Apr 3, 2003 06:31 PM
