aem cam gear help?!!?
i just installed an aem adjustable cam gear on my 1994 honda accord ex. i was wondering what i should adjust it to for the best performance? What Degrees Advance or Retard???? any help is appreciated
i have all the basic stuff intake header exhaust what degrees should i advance it to because my car hesistates around 1500 rpms and someone told me its the cam gear not adjusted right does that sound right??
its like the car shimmers around 1500 rpms in first gear. its an automatic.. and i had the tranny rebuit and it still does it. a mechanic told me its prolly something to do with the cam gear because i had all the belts replaced and that didnt help either?!?! any idea what it could be ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by secksiman19 »</TD></TR><TR><TD CLASS="quote">naws mang! yooz all wrong! dat iz da vtak kickin on
(pitiful attempt to create the mad tyte talk fw190 does....i have a feeling he will do me one better)</TD></TR></TABLE>
i guess i have to........:
h3rE's wH4t j0o g0tT4 d0. g3t tCh0 to0l5 4nD pUt 1t aT dA b3sT sP0t f0R p3rF0rmAnce, d3n j00 gOtts ta m4ke sUr3 d4 b3lT 1s t3h jDm. d3n wH3n j0o thR0w 0n s0m3 n4wz, d4 VT4K w1lL k1cK h4rD y00
u need reset it back to zero....then, if u want to try to make more power, advance the timing....AEM is a good company, so it should have come with directions to explain what each level represents, and which way is retard/advance.....
alright ill try that. but do you think the adjustments being off on the cam gear could cause the car to shimmer like i described? or do you think its something else ?mine came with no instructions... im a trial user so i cant post more than 5 post a day so ill keep editing this one!!!!! i got it from ebay brand new in a box!
Modified by fibercarbon at 2:13 AM 6/17/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fibercarbon »</TD></TR><TR><TD CLASS="quote">alright ill try that. but do you think the adjustments being off on the cam gear could cause the car to shimmer like i described? or do you think its something else ?mine came with no instructions...</TD></TR></TABLE>
that means it was either used, or a scam.....AEM always has long (and sometimes complicated) directions
</TD></TR></TABLE>that means it was either used, or a scam.....AEM always has long (and sometimes complicated) directions
wako182774
Honda Civic (2001 - 2005)
Jun 16, 2007 05:29 AM
Slow Rocket
Feb 25, 2002 05:45 PM
