auto to manaul conversion
Old Jun 16, 2004 | 06:05 PM
crazycampercarl's Avatar
Default auto to manaul conversion
i have a 90 lx and its an auto and i was going to throw in a jdm h22. but i want it to be a manual.I heard it is a pain in the *** to convert and wondering if i should just sell it and by a manual then do the swap. any input would be great
Old Jun 16, 2004 | 06:09 PM
fw190bvi's Avatar
Default Re: auto to manaul conversion (crazycampercarl)
search
Nick H's Avatar
New User
it's easy to convert once the motor is out...all you need are:
-clutch pedal and mounting bracket...
-brake pedal and mounting bracket...
-all hydraulic lines for the clutch (both from the pedal to the master cylinder and from the master cylinder to the slave cylinder)
-master and slave cylinders and mounting bracker for the m/c
-shifter and shift cables from a m/t accord
-5 speed ecu (which you should get with your swap)
since this is in a 4th gen, you may have to weld on a tranny mount...i know 5th gens you don't, but 4th gens are a little different...regardless, it's nothing that can't be done...everything except for the mount that needs welded bolts right in...
Old Jun 16, 2004 | 06:11 PM
Default Re: auto to manaul conversion (Nick H)
that easy what about wiring
Old Jun 16, 2004 | 06:13 PM
Nick H's Avatar
New User
here ya go, full how-to...although, i think they stuck with an auto ecu and somehow got it to work with the 5 speed...if i were you, i'd just swap to a 5 speed ecu as it's easier...
http://www.extremeredline.net/....html
Old Jun 16, 2004 | 06:15 PM
thanx
Old Jun 16, 2004 | 06:17 PM
Nick H's Avatar
New User
no problemo
tamadrummer1120
Feb 4, 2009 11:30 AM
FSTASNTZ
Feb 20, 2005 12:15 PM
Mr. Choi
Feb 26, 2003 12:02 PM
CmptchAV6
Feb 28, 2002 09:59 PM
