tranny experts need your advice!
Old Jun 16, 2004 | 12:56 PM
Race Egr's Avatar
Default tranny experts need your advice!
ok here is my problem, I am putting b16 gears in ls y80 casing everything is in there correct. However i noticed that when i **** the synchro sleeve on the mainshaft to 4th gear as far up as it will go with my hand that it will rub a tiny tiny bit against the countershaft 4th gear. When i put the casing and everything back toegether will it shift the contershaft up a little fixing this? I mean it barley touches it and that was just when i used my hand to hold it all the way up ?
Old Jun 16, 2004 | 01:44 PM
acy76's Avatar
Default Re: tranny experts need your advice! (ek-guru)
Once the countershaft seats in the snap ring at the top of the case, it should 'hang' a little higher in the case. I would double-check the assembly of the mainshaft though, just to be sure everything is on the way it should be.
Old Jun 16, 2004 | 06:28 PM
Race Egr's Avatar
Default Re: tranny experts need your advice! (acy76)
exactly what i was thinking i checked everything on both shafts 100 times so i know its right and had my freind check to and he says its good. thanks alot
MrExclusive
Feb 4, 2010 07:52 AM
vtechjunkie
Transmission & Drivetrain
Jan 31, 2010 07:46 PM
teg_95
10
Mar 30, 2009 06:19 PM
quis84
Jan 26, 2008 10:37 PM
ieatrice
Nov 22, 2004 05:06 AM
