5th gen Sub install through firewall
I am hooking up an amp in my 5th gen '96 accord v6 and i was wondering how you get the positive battery cable from the battery through the firewall? can anyone describe where to punch the wire through the firewall into the car without drilling?
also, any tips on mounting the sub box in the trunk to keep it from moving around when you make sharp turns?
thanks
thanks
you can run the power wire through the rubber groumet below the master cylinder, above your pedals .. Or you can just drill a hole somewhere around there.. esspically if your using something larger than 8 gauges ..
I ran my power cable through the firewall on the pass. side. If you follow the fuse box harness to the firewall youll see a large oval gromett, it enters the cabin above the ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anty »</TD></TR><TR><TD CLASS="quote">thx, but do i have to remove the fuse box to see it?
Sorry i forgot about moving the fusebox. yeah all you gotta do is remove a couple of bolts and move it to the side. If you follow the harness youll find a large oval shaped grommet. I cut a hole in mine w/ a blade and ran the cable through.
</TD></TR></TABLE>Sorry i forgot about moving the fusebox. yeah all you gotta do is remove a couple of bolts and move it to the side. If you follow the harness youll find a large oval shaped grommet. I cut a hole in mine w/ a blade and ran the cable through.
kriptik
Audio / Security / Video
Jun 16, 2005 09:42 AM
