Wastegate question.... need some advise
Old Jun 16, 2004 | 08:47 AM
Vinhtran17's Avatar
Default Wastegate question.... need some advise
I have a turboed my car and am running on a mark 2 deltawastegate. many people have told me to go with tial. the problem is, im not sure what size tial should i buy? (i heard that 38 mm is good) im planning on to run about 6-9 pounds daily driven. if anyone could give me the right size, it would be a great help.
thanks to all that helped
Old Jun 16, 2004 | 09:02 AM
Turbocivic94's Avatar
Default Re: Wastegate question.... need some advise (Vinhtran17)
just get 38mm and it would bolt right up. Its good enough for 400hp
Old Jun 16, 2004 | 09:24 AM
bluebullet's Avatar
Default Re: Wastegate question.... need some advise (Turbocivic94)
yep, TiAL 38mm will work perfect. Other options are the Turbosmart brand.
Old Jun 18, 2004 | 04:36 PM
Vinhtran17's Avatar
dumb question, is the tial wastegate adjustible? or do i just get the right spring and just tighten it?
Old Jun 19, 2004 | 02:37 PM
powerls's Avatar
get the turbosmart ultragate 35mm, it is smaller than the tial 38mm but flows 20% more. Plus it is made entirely of 253ma, tials are made of multiple metals and can corrode and collect deposits.
Old Jun 19, 2004 | 02:49 PM
alpha's Avatar
Default Re: (Vinhtran17)
You can switch out springs (easier than it sounds) or just a boost controller with the TiAL. Is your Delta II giving you any problems right now?
Old Jun 21, 2004 | 01:54 PM
Vinhtran17's Avatar
Default Re: (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">You can switch out springs (easier than it sounds) or just a boost controller with the TiAL. Is your Delta II giving you any problems right now?</TD></TR></TABLE>
yeah, i want to run about 6 or 7 pounds, but i see that i either boost creep , or i have a wastegate leak. not raelly sure, but i go past 6 up to like 9 or 10 on stock internals.
Old Jun 21, 2004 | 01:55 PM
Vinhtran17's Avatar
Default Re: (powerls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerls &raquo;</TD></TR><TR><TD CLASS="quote">get the turbosmart ultragate 35mm, it is smaller than the tial 38mm but flows 20% more. Plus it is made entirely of 253ma, tials are made of multiple metals and can corrode and collect deposits. </TD></TR></TABLE>
do you know where i can purchase this wastegate? thanks
Old Jun 21, 2004 | 03:21 PM
powerls's Avatar
I know you can order them from Eagleday.com, Peter Farrell sells them. If you look, you'll find em
juanb
Nov 23, 2006 09:36 PM
operatic
Dec 13, 2004 03:41 PM
ATF Kuk
Sep 15, 2004 09:50 AM
queez
Dec 11, 2003 08:24 PM
DXturbo
May 23, 2003 08:10 AM
