99 gsr jsut put in jdm 4-1 type r headers in what kind of test pipe do I use?????
Old Jun 16, 2004 | 08:25 AM
TYPERman2001's Avatar
* B A N N E D *
Default 99 gsr jsut put in jdm 4-1 type r headers in what kind of test pipe do I use?????
99 gsr with jdm 4-1 headers and i got usdm type r b pipe and axle back
where can i get a test pipe that will work with this setup
i dont wanna drive around straight from header , can anyone help or had this same situation
Old Jun 16, 2004 | 09:51 AM
nickgmiller04's Avatar
Default Re: 99 gsr jsut put in jdm 4-1 type r headers in what kind of test pipe do I use????? (TYPERman2001)
try meineke or carx. a straight(test) pipe is just a peice of piping connecting your header collector and your exhaust. youll need a custom one installed at a muffler shop
Old Jun 16, 2004 | 10:30 AM
neverscared's Avatar
just like he said, a strait pipe. Cost like 30 bucks around my way. You kinda of got get the shop hustled. Most of the time they can make it but won't install, unless you give dude a nice tip.
Old Jun 16, 2004 | 12:25 PM
daLixz25's Avatar
Forget the testpipe...go with a custom Carsound Cat.
Similar gains, less noise.
Old Jun 16, 2004 | 01:12 PM
* B A N N E D *
Default Re: (daLixz25)
is there any place that sells a test pipe allready meade for my setup
Old Jun 16, 2004 | 02:05 PM
Padawan's Avatar
Darth ModerVader
Default Re: (TYPERman2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> SMS Products
4747 Ewell Rd
Fredericksburg, VA 22408
SMSP Headers - Because diameter and length do make a difference
SMSP Exhausts - You don't have to be loud to make noise, email for the least expensive kit prices around
SMS Products now carries Honda/Acura Tranny Rebuild Kits with Synchros, Light Weight Flywheels, Mid and Hi Performance Clutches & Pressure Plates
OBDII California Compliant Cats Now Available
540-287-6384
smsproducts@adelphia.net
I'd spring for a Car Sound instead (although Dave can make you either one). Do the environment a favor, and avoid the possibility of a multi-thousand dollar fine.
Old Jun 16, 2004 | 02:09 PM
01DC-2's Avatar
just go to a muffler shop and have them make one for you.
Old Jun 16, 2004 | 02:11 PM
* B A N N E D *
Default Re: 99 gsr jsut put in jdm 4-1 type r headers in what kind of test pipe do I use????? (01DC-2)
DO I NEED A 2.5 TO 2.25 CAT SINCE MY B PIPE IS USDM ITR ???
Old Jun 16, 2004 | 02:18 PM
Padawan's Avatar
Darth ModerVader
No, a properly made 2.5" cat (or test pipe) will bolt up to the ITR B-pipe. It would, however, be beneficial to remove the very restrictive bottle neck at the ITR cat/B-pipe flange and replace it with a tapered 2.5" -&gt; 2.25" adapter.
Old Jun 16, 2004 | 04:34 PM
* B A N N E D *
Default Re: 99 gsr jsut put in jdm 4-1 type r headers in what kind of test pipe do I use????? (Padawan)
where can i find a test pipe like this
so a 2.5 inch test pipe will fit my usdm itr b pipe???
i was thinkign of the j's racing test pipe on jhp.com
Old Jun 16, 2004 | 04:48 PM
Padawan's Avatar
Darth ModerVader
Yes, a 2.5" test pipe will bolt to your exhaust, but will meet the severe bottle neck at the B-pipe flange. SMSP (the info I posted above) can construct a very high-quality one for you, but you can also most likly get a local muffler shop to fabricate one for you.
Old Jun 16, 2004 | 04:49 PM
* B A N N E D *
thanx for the advice kteller.com i jsut discovered has 2.5 inch test pipes for $60
Old Jun 17, 2004 | 07:40 PM
* B A N N E D *
Old Jun 17, 2004 | 11:42 PM
DC2*Integra's Avatar
i went to a muffler shop and they made/install for $40.
Old Jun 19, 2004 | 08:51 AM
* B A N N E D *
Default Re: 99 gsr jsut put in jdm 4-1 type r headers in what kind of test pipe do I use????? (DC2*Integra)
Kruzer
Mar 13, 2011 08:31 PM
Azn Kenny
Sep 26, 2007 11:42 AM
Azcheron
Jun 17, 2005 06:38 AM
Scubster
Feb 1, 2005 04:00 PM
xkhalil333x
Oct 13, 2003 08:49 PM
