Help, After turbo install Car start but stall!!!
When i finish installthe turbo, i crank it like 5 time without the spark plug wire in, to get oil to turbo. but when i put the spark plug wire back in and crank, the car start but it would stall a second or two later, when i try to floor the gas pedal, it would rev up to about 4 for a little then stall. Did i install the fuel injector wrong or something.
Im running on a greddy turbo kit with aftermarket intercool+BOV. usingm 310 injector and the greddy blue box??? WHAT IS WRONG, Someone HELP!!!
If it start then stall like that, then it must be something wrong with the fuel right??? could i wire it incorrectly or something??? is there a specific pattern for the injector or they can be put anywhere???
you have to wire it up exactly like the instructions say. injector 1, 2, 3, 4 all have specific wires.
Check that you don't have a wire punched anywhere.
You should be through ECU codes, my guess would be 70,71,72,73 - which are all misfire codes due to too much fuel being injected.
How do i tell which injector is for which cylinder, first i have a little fuel leak but i fixed that and now it started but it would stall. same thing everytime...
On the 310cc injector clip i seen these number PED39, PED41, PED43, and PED48<-- not sure if it 48 but it lok kinda like it. Does these number suppose to be in specific cylinder???
I look like the fuel line to the fuel filter, and there is no fuel in it, i pull it out and it dry. fuel should always present in the fuel line right??? does this have anything to do with my fuel pump??? everything was working fine before install turbo, how could it die???
Just install a walbro 255lp fuel pump, still no fuel line at the fuel at at the fuel filter, but there is fuel in the fuel filter??? Try to start the car, it crank but now it wont even start. Could my spark plug wire die too now??? someone help!!!!
Check all your fuses. Also, check your MAP Sensor and make sure its hooked up and not loose. Is a CEL and codes being thrown?? Did you swap your sparkplugs? Maybe they are fouled. When you turn your key to the on position, do you hear your fuel pump?
Which fuses do i check, The one access in the engine bay??? I dont know if i hear the fuel pump but i didnt really pay attention to that...i think i also have a check engine light since i turn it on and leave for while and it still on??? i never even touch the spark plug, i jsut unhook the spark plug wire at the distrib....
Oh and greddy instruction say something about connecting/installing a water bypass hose which i never did, but i doubt that the problem???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">yes u have a cel... check it</TD></TR></TABLE>
LOL would have been the first thing I did
I had the same problem. Car would start and would live with gas but would stall if I let it idle. Turns out my spark plugs were gone to **** and I had oil in spark hole #1. Fixed those two things and it started right up
I am OBDII and my codes were
71, 72, 73, 74. Misfires in cylinders 1,2,3 and 4
stevil_knevil
Sep 7, 2009 07:49 PM
