Already a wire in A17, what to do?
Old Jun 15, 2004 | 10:21 PM
sleeping beauty's Avatar
Default Already a wire in A17, what to do?
Ok, I've read a jillion times that to wire up the IAB's you have to run the wires from the plug straight to the ECU. My problem is that there is already a wire plugged into A17. Is that slot supposed to be empty or am I supposed to remove it or do I splice into it? That's for the help.
Old Jun 16, 2004 | 12:50 PM
Combustion Contraption's Avatar
depends what harness youre using. a little more info on the setup would help.
Old Jun 16, 2004 | 01:12 PM
Default Re: Already a wire in A17, what to do? (sleeping beauty)
My bad. It's a 93 Civic EX harness in the firewall and a 94 GSR harness on the engine.
Old Jun 16, 2004 | 04:48 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeping beauty &raquo;</TD></TR><TR><TD CLASS="quote">My bad. It's a 93 Civic EX harness in the firewall and a 94 GSR harness on the engine.</TD></TR></TABLE>
its suppose to be a blank pinout if your Ex is 5speed.
Only if its an AUTO EX, then a wire should be in the A17 spot for an auto transmssion related thing.
Old Jun 17, 2004 | 09:44 AM
Default Re: Already a wire in A17, what to do? (Katman)
My bad, AGAIN. It is an auto wiring harness. I'm also doing the auto to manual swap. My mind has been going at a billion miles per hour trying to straighten this stuff out. I'm such a n00b. Alright, so I'll just remove that pin. Thanks
Old Jun 17, 2004 | 10:35 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeping beauty &raquo;</TD></TR><TR><TD CLASS="quote">My bad, AGAIN. It is an auto wiring harness. I'm also doing the auto to manual swap. My mind has been going at a billion miles per hour trying to straighten this stuff out. I'm such a n00b. Alright, so I'll just remove that pin. Thanks</TD></TR></TABLE>
heh...there we go
so yeah, just reuse the A17 pinout location for the IAB and you should be set..
Old Jun 17, 2004 | 02:30 PM
egsleepercivic's Avatar
I never wired IABs since I have a B16a, but could'nt you just move the wire on the engine harness at the shock tower to match up with A17 on the shock tower, seems like this would make for ultra clean wiring
Old Jun 17, 2004 | 03:13 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">heh...there we go
so yeah, just reuse the A17 pinout location for the IAB and you should be set..</TD></TR></TABLE>
Katman: the walking, talking honda wiring diagram.
Old Jun 18, 2004 | 10:04 AM
Honda Sport's Avatar
do you have to wire up the IAB? will it give off a CEL? any lack of performance from not wiring it up?
Blacknight117
Dec 24, 2011 05:20 PM
project 2two9
Jul 22, 2006 09:54 PM
shadykit
Jul 23, 2004 06:35 PM
kholmes
Feb 18, 2004 10:22 AM
