Tuning Problems!
Old Jun 15, 2004 | 09:08 PM
jeux's Avatar
Default Tuning Problems!
Car has trouble starting sometimes and I have also just recently replaced the spark plugs. The problem is when I try to tune the apexi vafc, adjustments made to it does not affect the actual a/f ratio on the dyno as it should. On a side note the 2nd o2 sensor is unplugged and the ecu occassionally throws a code 63. Does the problem lie with the ecu or vafc? Or is it a fuel problem? Sensor? The dyno indicates that the car is running very lean.
Old Jun 15, 2004 | 09:15 PM
BlueR's Avatar
Default Re: Tuning Problems! (jeux)
vafc can only do so much...
not knowing what your actual setup is...
i guess that you will probably need a fuel pressure regulator and larger injectors
Old Jun 15, 2004 | 09:23 PM
jeux's Avatar
Default Re: Tuning Problems! (BlueR)
aem cold air intake, spoon n1 muffler and a hollow cat plus a fuel pressure regulator but i am unsure of its settings
Old Jun 15, 2004 | 09:26 PM
BlueR's Avatar
get a gauge for the fpr
turbo boost
Aug 8, 2005 06:08 PM
2lobes1engine
May 16, 2004 04:06 PM
91integraLSVTEC
16
Mar 7, 2004 07:16 AM
kHoA DoGG
Oct 9, 2002 08:37 AM
10seconds
Jul 15, 2002 02:00 PM
