code 4, help?
i got a 89 crx hf and it wont rev past 2500 rpm's so i check the codes and i get a code 4. the crank shaft position sensor. what should i do first to try to fix this?????
I have already searched just looking for some advice...
Check your wiring first and make sure everything is secure. Most likely however, you will probably need to change your distributor as the sensor is located in it and unless you have the tools and a spare sensor, you can't change it out.
SomeDude56
Sep 26, 2005 02:31 PM
mraudio13
Sep 19, 2002 05:34 PM
