solid cel on hondata, red light blinking, car runs SOMEWHAT alright
Old Jun 15, 2004 | 05:55 PM
boostedcivichatchbacksi's Avatar
Default solid cel on hondata, red light blinking, car runs SOMEWHAT alright
d16z6, hondata s200b, basemap chip... now a while back i turned on the car (after i got my engine drop done) and the ecu started smoking and this little black piece burnt up and i had a cel from then on... i figured it out earlier that it was the air intake temp sensor and i checked the code and now the light just stays on... the odd thing is that the car runs fine in boost but when normally driving at partial throttle it boggs... would this be cuase of the basemap? or is it the burnt ecu? this is the only problem that i have had with it. plz help thanks
Old Jun 16, 2004 | 11:22 AM
Spunkster's Avatar
Default Re: solid cel on hondata, red light blinking, car runs SOMEWHAT alright (boostedcivichatchbacksi)
More than likely you have a wiring problem wich casued the ecu to fry....check your wiring and then replace the ECU.
attack666
Engine Management and Tuning
Jan 23, 2013 09:31 AM
kardal86
May 24, 2010 08:59 PM
skUnK2jdm
Feb 7, 2008 09:44 PM
B18C1CYA
Apr 17, 2004 09:00 PM
Double121
Oct 31, 2003 10:14 AM
