idle problem air conditioning stalls car
Old Jun 15, 2004 | 01:14 PM
Chris22215's Avatar
Default idle problem air conditioning stalls car
alright, I've got a 95 integra ls. I've got the typical intake header and exhaust and a chipped ecu. I just added some crower 404s with the valve springs and retainers. The car idled wonderful for the cams. I installed some buddy club cam gears and a b&m fpr w/gauge yesterday, and something's off. When I turn on ac the car slowly dies. The fuel pressure is set at 43psi. I don't know what's wrong, I didn't have this problem before the cam gears. Could my timing be off?
Thanks,
Chris
Old Jun 16, 2004 | 12:06 AM
Chris22215's Avatar
Default Re: idle problem air conditioning stalls car (Chris22215)
Oh, it also kinda hesitates when I'm driving down the road at a constant speed. I think it's my timing that's off a little bit. Any advice would help.
Chris
Old Jun 16, 2004 | 08:53 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris22215 &raquo;</TD></TR><TR><TD CLASS="quote">I think it's my timing that's off a little bit. Any advice would help.</TD></TR></TABLE>It's easy to measure spark timing. Then you won't have to guess whether that's the problem. It's not even that difficult to double-check your camshaft timing.
Old Jun 16, 2004 | 09:18 AM
IVI's Avatar
IVI
Default Re: idle problem air conditioning stalls car (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">It's easy to measure spark timing. Then you won't have to guess whether that's the problem. It's not even that difficult to double-check your camshaft timing.</TD></TR></TABLE>
care to explain how to ?
Old Jun 16, 2004 | 09:35 AM
JimBlake's Avatar
Default Re: idle problem air conditioning stalls car (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">care to explain how to ?</TD></TR></TABLE>
Warm up the engine, plug a jumper into the service-check connector, hook up your timing light. Shine it on the crank pulley while the engine is idling, the timing mark should line up with the pointer that's molded into the lower timing cover.
For anything other than a '95 Integra, some details may vary. Like some older cars you might have to disconnect or plug some vacuum hose, or some cars you don't have to jumper the SCS plug...
Old Jun 16, 2004 | 01:59 PM
Chris22215's Avatar
thanks for the info man. I'm going to check it tomorrow morning. I had to pick up my brother's car. He just got a b18c swap.
Chris
ej1vtec
Jun 6, 2006 08:17 AM
downest
May 23, 2006 08:36 PM
1990 CRX Si
Nov 15, 2005 12:09 PM
hatchbackhonda
10
Sep 15, 2004 06:26 AM
B00ST2nR
Aug 13, 2002 03:47 AM
