FUEL injectors took a piss... seing whats wrong
Old Jun 15, 2004 | 12:40 PM
itsm3paul's Avatar
Default FUEL injectors took a ****... seing whats wrong
thanks guys fixed the problem
Modified by itsm3paul at 7:25 PM 6/21/2004
Old Jun 15, 2004 | 01:21 PM
itsm3paul's Avatar
Default Re: FUEL injectors took a ****... seing whats wrong (itsm3paul)
ANYONE?
Old Jun 15, 2004 | 01:48 PM
RCautoworks's Avatar
What kind of car is it ? In the first pic you show and injector, is it leaking out of that or a hose ? Did you put the spacer in between the fuel rail and manifold ? You could of ripped an o ring.
Old Jun 15, 2004 | 03:24 PM
seks727's Avatar
I bet you peirced the injectors o-ring when reinstalling it...you can buy these seperate from your honda parts store, not much.
To extract the fuel rail studs from the IM just use two of your nuts [INSERT LAUGHS HERE] off of your fuel rail studs.
Mount one nut backwards onto the first fuel rail stud to extract, about half way down, and then mount the next nut onto the same stud properly until it sits flush with the first nut.
Torque down both nuts so they sit tightly against one another, and with a open ended wrench turn the bottom nut counter clock wise as you would if you were to extract or loosen a regular bolt from an object.
The stud should loosen up and come out.
Old Jun 15, 2004 | 04:39 PM
DaiJekBok's Avatar
Default Re: FUEL injectors took a ****... seing whats wrong (seks727)
I damaged my studs beyond repair while trying to extract them so I ordered new ones. However, I got impatient before they got here and found 3 10mm bolts that threaded right in and have held it securely for about a year now.
Old Jun 17, 2004 | 08:48 AM
itsm3paul's Avatar
FIXED THE PROBLEM THANKS GUYS!
Old Jun 17, 2004 | 11:38 AM
dc5r2002's Avatar
it is the orings on the injector get a rebuild kit they are 9 bucks and replace the orings i had the same problem a while ago with my friends car
EGk3nrock
Feb 28, 2007 09:11 PM
gunmetalcivic
Apr 17, 2006 11:55 PM
Judah
15
Nov 1, 2003 10:25 AM
YumVTEC
Mar 25, 2003 07:18 AM
Tripz
Jun 20, 2002 05:45 PM
