ball joint boot question?
Old Jun 15, 2004 | 12:11 PM
teawoboba's Avatar
Default ball joint boot question?
how would you change a torn ball joint boot? would I have to replace the whole ball joint? for both the upper and lower control arm? thanks.
Old Jun 16, 2004 | 08:19 AM
JimBlake's Avatar
Default Re: ball joint boot question? (teawoboba)
There's a spiral spring thing holding the big end of the boot. You can use a $$pecial tool for that or you can pry around it with a couple small screwdrivers or something like that. Then you just pop the old boot off, maybe put some fresh grease in, & put the new boot on. Then work that spring clip on without letting it tear the NEW boot.
If the rubber boot has been torn for a while, then there's probably dirt & crud in there. In that case I'd probably replace the joint.
Old Jun 16, 2004 | 09:20 AM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teawoboba &raquo;</TD></TR><TR><TD CLASS="quote">how would you change a torn ball joint boot? would I have to replace the whole ball joint? for both the upper and lower control arm? thanks.</TD></TR></TABLE>
replace it. dont grease it. itll end up breaking without notice, and you dont want that to break while your driving. the whole ball joint must be changed on the lower. it presses out. the upper ball joint can not be removed, you must replace the upper control arm.
Old Jun 16, 2004 | 09:58 AM
spark plugs.
Guest
Posts: n/a
Default Re: ball joint boot question? (IVI)
replace the whole joint.
retriever99
Jan 8, 2020 07:12 AM
themtn
Honda Civic (2001 - 2005)
Mar 26, 2010 03:01 PM
Hala
Aug 8, 2009 10:31 PM
squeaky
14
Aug 29, 2004 12:08 PM
Aron Parsons
Aug 1, 2002 05:22 PM
