JDM H22A Redline/Fuel Cutoff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxTrix »</TD></TR><TR><TD CLASS="quote">With a chipped ecu I rev my h22 to 8500 rpm but on a stock jdm ecu its around 7800</TD></TR></TABLE>
Stock h22?
Stock h22?
Yup 8500 on my chipped ecu adn even took it up to 9000 a few times to test it out but it felt like it was not makeing power after 8500.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twin-cam »</TD></TR><TR><TD CLASS="quote">It redlines at 7800 rpm, but it cuts between 8200 and 8400rpm.
AT engines rev 500rpm lower.</TD></TR></TABLE>
I wouldn't take it up that high. I'm 99.9% positive the stock redline set by Honda is either 7200 or 7400.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxTrix »</TD></TR><TR><TD CLASS="quote">Yup 8500 on my chipped ecu adn even took it up to 9000 a few times to test it out but it felt like it was not makeing power after 8500.</TD></TR></TABLE>
Your lucky you didn't blow the **** out of your motor if it was stock. I hope you don't regularly take it up that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic »</TD></TR><TR><TD CLASS="quote">depends on what ecu u are using.</TD></TR></TABLE>
Couldn't have said it better myself, but with the stock JDM P13 (obd1) it's 7400 rpm.
By the way, you might get more information about a particular engine if you post in the forum of the car that it originally came from. Posting here you'll just get us old folks giving you hearsay and fairy tales.
[QUOTE=DarkKnight[DMD]]
Took it to 8500 often and never had a problem all I had was intake, header, prodrive oil gear and exhaust. Ran it on slicks and street tires reving it to 8500 no problem.
Ever put it on a dyno and take it up that high? I'd like to see if you were actually making any power at all past 7600 or so.
IF you are running a stock jdm p13 ecu----it cuts at around 7800
a stock usdm p13 ecu revs to round 7500
some people have said that their stock jdm p13-ecu's go to 8000 its just tach error
This might explain things, I'm still using my 98 RS Integra cluster. Should have the face on my first passenger when I took it up to 7500+, he almost jumped in my back seat LOL
prelude2.2vtec
May 4, 2007 11:16 AM
