what is wheel hop
Old Nov 14, 2001 | 11:10 AM
pr0digy1's Avatar
New User
Default what is wheel hop
I've seen ppl talking about wheel hop but i'm still not sure exactly what it is and how i know when it's happening. Could someone explain wheel hop to me?
thanx
Old Nov 14, 2001 | 11:46 AM
Greyout's Avatar
Default Re: what is wheel hop (pr0digy1)
stop the car.... rev it up.... dump the clutch. the feeling that your fillings are gonna come loose and the dash is gonna rattle off the frame? thats wheel hop
Old Nov 14, 2001 | 11:52 AM
pr0digy1's Avatar
New User
Default Re: what is wheel hop (JDM LUDE)
thanx for the info
Old Nov 14, 2001 | 12:12 PM
vpforeva's Avatar
New User
is wheel hop the product of not gettin traction on your wheels?
Old Nov 14, 2001 | 12:30 PM
John's Avatar
New User
Default Re: what is wheel hop (vpforeva)
Wheel hop is also known as peg-legging... It occurs on an open differential Hondas... which to an extent drives the power to the wheel with the least amount of grip... so if you break traction on a launch, more power will be go the path of least resistance: to the spinning wheel.
You can test this by putting your front right wheel on ice (in the winter obviously), and make sure your front left wheel are on drive pavement... try and start up and you'll notice that the right wheel will spin and you won't move anywhere!
sucks not to have an LSD now doesn't it?
Old Nov 14, 2001 | 12:38 PM
Greyout's Avatar
Default Re: what is wheel hop (DunReit)
no, thats not quite wheel hop. Wheel hop is caused by the following:
-you launch... weight shifts off the front wheels, you loose traction
-when you loose traction, acceleration reduces. more weight in the front, gain traction back
-the increased traction gives you acceleration. which shifts weight back, causing you to loose traction again
-repeat over and over again very fast until you break something or you shake yourself to pieces.
***EDIT: I THINK***
[Modified by JDM LUDE, 9:41 PM 11/14/2001]
Old Nov 14, 2001 | 12:47 PM
Import RP's Avatar
It is a bad thing.
Old Nov 14, 2001 | 02:10 PM
pr0digy1's Avatar
New User
Default Re: what is wheel hop (Pyrochaos38)
and what does LSD stand for?
i'm not talking about acid here..
Old Nov 14, 2001 | 02:35 PM
Type Goch's Avatar
New User
limited slip differential - which should not affect launches.
Old Nov 14, 2001 | 03:01 PM
Greyout's Avatar
Default Re: what is wheel hop (Type Goch)
well.... it wil affect launches, but not so much affect wheel hop
Old Nov 14, 2001 | 03:29 PM
prelude1897's Avatar
Wheel hop sucks. I hate whenever I do that when I'm trying to race someone. It doesn't happen much, but I hate when it does it.
Old Nov 15, 2001 | 04:29 AM
LudeBehavior's Avatar
New User
Default Re: what is wheel hop (prelude1897)
Yeah wheel hop is bad your chassis flexes under wheel hop. It can't be good. It happens all day when I race. But I fugured I could solve it with some springs and urethane motor mounts.
Old Nov 15, 2001 | 11:49 PM
ELUD THS's Avatar
New User
Default Re: what is wheel hop (LudeBehavior)
to prevent wheel hop to ride the clutch for a bit them release it gradully that way you maintain your RPM"S but you burn your clutch.
DEEABLO
Jun 10, 2009 08:02 PM
HATCH DIS CATCH
Mar 26, 2006 10:29 PM
