Finally broke down and went to acura
After a month of riding around with my abs light on and a loud *** clunk cokming from the rear of the car after lowering the car i finally brought it to acura and was told its gonna cost 290 for two new control arms and bushings and 75 foir a badly needed alignment...worse news i got in a while
O well atleast i will have it fixed
Someone needs to start learning to work on their own car...
Taking your car to the dealership for maintenance, repair and getting an *** rapeage on the price
Be a man and do it yourself.
NRg
NRg
Well ip[osted like 4 topics asking what it could be and nobody had a clue, if i knew it was the control arms i could have done it, i knew i was going to have problems as soon as i broke the bolt trying to get them off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eric8876 »</TD></TR><TR><TD CLASS="quote">Well ip[osted like 4 topics asking what it could be and nobody had a clue, if i knew it was the control arms i could have done it, i knew i was going to have problems as soon as i broke the bolt trying to get them off </TD></TR></TABLE>
Still doesn't explain the ABS light. Did you break one of the wires running along the LCA's in back? If so, methinks it will cost a bit more than $290 for replacing the control arms.
Yeah I cant see the control arms causing the abs light to be one. Unless you somehow got an abs sensor line wrapped around the arm, but I think you would have to try to do that. If you broke a abs sensor line its not a cheap fix. When I broke when, the dealer quoted me 120ish for a new one.
you couldve went to acura for them to diagnose at theyre 90 dollar rate and then went home and fixed the problems yourself if no one could figure it out.
but also you cant expect people to figuer out a post that says
'car is making noise, what is it? does it at 35 mph.'
Charlienofun
Feb 18, 2015 08:29 PM
