Please help, thowing coed 10 after mpfi and mini me
Old Jun 14, 2004 | 12:06 PM
Layziebtnh055's Avatar
Default Please help, thowing coed 10 after mpfi and mini me
when i try to start the car it just keeps turning over, every couple seconds i get a put sound out the exuahst, i need help fast from anybody who knows anything, could my timing be why it isnt starting?
Old Jun 14, 2004 | 12:52 PM
warrick's Avatar
Default Re: Please help, thowing coed 10 after mpfi and mini me (Layziebtnh055)
double check your timing belt, make sure you didn't miss a tooth.
code 10 is CYP, double check your MPFI wiring, and make sure you are using either a ZC or an Si distributor.
what ecu are you using?
Old Jun 14, 2004 | 01:22 PM
ok i fixed the code 10 but the car stil wont start, i need help ftast
Old Jun 14, 2004 | 01:56 PM
come on please help sombody
Old Jun 14, 2004 | 02:16 PM
91civicEX's Avatar
firing order? so no more codes and its not starting? try switching the two white wires at the dizzy.
Old Jun 14, 2004 | 05:58 PM
ham's Avatar
ham
http://aarc.epnet.com/applicat...L.gif
Old Jun 14, 2004 | 08:51 PM
96-EJ6 B18C's Avatar
Default Re: Please help, thowing coed 10 after mpfi and mini me (zcnos)
Up for more info...My buddies car is doing the same thing and it is NOT the firing order or the white wires at the distributor.
Slink2000
Mar 17, 2006 03:03 PM
Schaz
May 18, 2005 10:53 PM
civicboisi
14
Dec 20, 2004 09:08 PM
South Bay Surfer
Feb 23, 2004 10:01 AM
VTgringo
Jun 23, 2003 07:28 PM
