Shift Linkage Pin Lost (searched)
Old Jun 14, 2004 | 08:45 AM
tegmech's Avatar
Default Shift Linkage Pin Lost (searched)
Couple days ago I lost Cyphears shift linkage pin that connects it to the tranny. I searched and all I read was that everyone forced a 10 mil bolt in there. However, we have an m8 bolt in there right now with a bit of play. However, I have never heard of anyone using a spring pin. Has anyone given this a try or think that it would work. Also any other ideas? TIA
Old Jun 14, 2004 | 08:56 AM
N2O's Avatar
N2O
Default Re: Shift Linkage Pin Lost (tegmech)
The best thing to use is a spring pin or the stock pin. The reason for using a bolt is that it is faster and easer to remove when you have to change a trans between rounds. The problem with using a bolt is that it ovals out the holes in the linkage and you end up with to much slop in the shifter.
Old Jun 14, 2004 | 09:06 AM
wickedEFguy's Avatar
Default Re: Shift Linkage Pin Lost (N2O)
Go to honda and spend $7 fo the pin, yeah it's a bitch to remove and put back in but you have 0 slop in the shifter and feels a lot better then some bolt.
Old Jun 14, 2004 | 09:50 AM
tegmech's Avatar
Default Re: Shift Linkage Pin Lost (wickedEFguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedEFguy &raquo;</TD></TR><TR><TD CLASS="quote">Go to honda and spend $7 fo the pin, yeah it's a bitch to remove and put back in but you have 0 slop in the shifter and feels a lot better then some bolt.
well, the reason for asking about the spring pin is that I work for an industrial supplier and have the spring pin in stock. And the cost for me is only 18 cents. Diameter is 8.65mm unsprung.
edit: i also found a few dowel pins that are a perfect 8.0mm. Also, I have never had a problem getting out the original pin....Just use an air hammer and its out in 3 seconds.
Old Jun 14, 2004 | 10:29 PM
Jaker's Avatar
https://honda-tech.com/zerothread?id=881099
Look specifically for the posts by CRX Lee about slotting the end of the shift linkage where the pin goes through.
Vtec4me
Sep 13, 2007 05:58 AM
redboost10
Jul 22, 2007 06:58 AM
streetracerof06
Oct 27, 2005 09:20 AM
BigDawwg6969
Aug 16, 2005 09:59 AM
allmotorls95
Sep 10, 2002 09:00 AM
