Amp Wiring Help 2004 Civic
Old Jun 14, 2004 | 05:31 AM
timmayacc's Avatar
Default Amp Wiring Help 2004 Civic
Hey guys, I need some help with wiring my car up for an amp.
I was wondering if anyone has put in an amp wiring kit in a 2004 civic, I am trying to figure out where in the firewall I can put my positive cable through. I'd rather not drill any holes. And if I have to where would be the best place to drill.
Thanks in a advance
Old Jun 14, 2004 | 07:27 AM
spark plugs.
Guest
Posts: n/a
Default Re: Amp Wiring Help 2004 Civic (timmayacc)
there should be a hole with a grommet and wires already passing through. if not, drill a hole, IT'S NOT THAT HARD!!!
Old Jun 14, 2004 | 10:38 AM
Goatsterrman's Avatar
Default Re: Amp Wiring Help 2004 Civic (trouble codes)
Is your car a Manuel or Auto, if it's an Auto there should be a rubber grommet where the clutch pedal would go through, it's a nice place for all Auto Civics, Like previously stated if you can't find one then just find a spot clear on both sides and drill a hole. Civics generally are fairly easy to find a spot on.
Ohmega
Audio / Security / Video
11
May 29, 2016 02:41 PM
dleccord
Jan 16, 2010 10:11 PM
D for D series
Mar 9, 2005 12:24 PM
lenn
Sep 7, 2004 06:52 AM
