acura integra 92 ABS problem
Old Jun 14, 2004 | 12:38 AM
zlamoab's Avatar
Default acura integra 92 ABS problem
Hi all..
Can anyone help me out?
I got acura integra 92 and had ABS light is on.
If it is the sensor problem, can you locate the sensor?
Or other problem??
thanx~!
Old Jun 14, 2004 | 12:44 AM
xplanetearth420x's Avatar
Default Re: acura integra 92 ABS problem (zlamoab)
i have a 95 and my abs is out
your supose to get it checked
every ten years or something
Old Jun 14, 2004 | 07:07 AM
gtfour43's Avatar
Default Re: acura integra 92 ABS problem (xplanetearth420x)
Try checking here. Hope this helps
http://www.g2ic.com/tegtips/brakesus/6.html
Old Jun 14, 2004 | 07:45 AM
Dawsonb17a's Avatar
New User
Default Re: acura integra 92 ABS problem (gtfour43)
Check to see if you're low on brake fluid. My ABS light came one when I was low on brake fluid once. Is your parking brake light on too?
Old Jun 14, 2004 | 12:38 PM
jdecks23's Avatar
I would use the link that gtfour43 provided first and if you cant figure that out then if you are willing to pay 70 bucks or so, bring it to an Acura dealer and they will diagnos the problem, in my case and most others it was a sensor. Acura quotes a sensor for 225 installed, I went to the junkyard and bought a left front sensor for 10 BUCKS!! Problem solved
speedking
Jan 7, 2010 12:21 AM
tsunami604
Oct 29, 2007 04:24 AM
xxmastermindxx
Jul 6, 2006 05:42 PM
IntegraLs94Cam
Mar 29, 2005 05:24 PM
EF8 JUNKIE9
Oct 10, 2003 02:08 AM
