any one have there car stolen using an autoloc
hey i was wondering if anyone on this board has had there car stolem while using an autoloc?????????? thanx in advance!!!!!!!!!!!!!!!!!!!
yes,
people have had their car stolen with no ECU or distributor too.
No honda is safe
PeeWee herman couldnt even save his bike from getting stolen by tieing it up with 1000ft of chain.
It sucks to look at it like this but it is true.
My buddies VW was stolen out of his garage while he was at work. In a residential neighborhood.
No honda is safe
Yes, Ive heard of many cars being stolen with AutoLock and many other devices...
basically, if they want it bad enough, they'll get it
I was wondering about this, since nothing works around here, did anybody try to use one of those locks that lock your shifter in place. Back in my old country they used to have these lock on manual cars, it's basicly a bar with a lock that goes straigh into the shifter assembly. But then again you can always push in the clutch and roll the car onto the flatbed.
I bet you that they would still steal it. Along with the post, lol. Seriously man, I heard about the car getting jacked from the garage.
yes. my friends car got stolen with an autolock. apparently on EKs if you put it on somewhat loose the clutch pedal can be bent a certain way just enough to slide the autolock off. i strongly suggest installing atleast 2 fuel cut off switches with your autolock
This guys car got stolen with an autolock
my boy got his car stolen with the autoloc...All they did was tow it right out of his driveway...they found it in a near by town striped!......JUST KEEP YOUR EYE"S OUT FOR HATERS!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EK9 »</TD></TR><TR><TD CLASS="quote">yes,
No honda is safe
My buddies VW was stolen out of his garage while he was at work. In a residential neighborhood.</TD></TR></TABLE>
Hahahahaha that is the funniest **** i have read in awhile
I see alot of people talking about gettign their Honda jacked. I am so naive...where I live, if a car got jacked it would make the news all day. I wish someoen would jack my Civic, then maybe I could get an SRT4 or a Spec-V
No honda is safe
along these lines is there a way for them to tow ur car if they cant inside ur car (just assume) and u have ur hard *** ebarke all the way up and the car in gear, is it possible.
they can still drag the car on to the flat bed no matter what. all 4 wheels could be locked the tow truck can still drag it up to the flat bed i seen it done many times. when i used to work on the parkway watching them pull cars that got in accidents on the the flat bed. they can basically pull almost anything on to it
i doubt anyone will tow my car i know the auto lock is useless to a tow truck!!!!!!!!!!!! im just saying in general has anyone in here had there car stolen while using an auto lock correctly????????????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMaxx »</TD></TR><TR><TD CLASS="quote">
Holy ****. Where did you find that? Makes me mad that they are cocky about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAccord96 »</TD></TR><TR><TD CLASS="quote">
Holy ****. Where did you find that? Makes me mad that they are cocky about it.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=892828
mad fucked up
mike
mad fucked up
mike
heres how to prevent your **** from getting jacked:
1) grab a welder
2) buy a brieface
3) remove the handle from the briefcase
4) weld the handle to your valve cover
5) get a plasma cutter
6) when leaving the car, power on the plasma cutter, cut away ur tranny and anything holding ur motor in place...
7) walk away with motor in hand
1) grab a welder
2) buy a brieface
uhh? ok.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MCall »</TD></TR><TR><TD CLASS="quote">heres how to prevent your **** from getting jacked:
1) grab a welder
2) buy a brieface
7) walk away with motor in hand</TD></TR></TABLE>
1) grab a welder
2) buy a brieface
speckersmove
Nov 13, 2008 12:28 PM
mister2racer
11
Aug 21, 2003 12:41 PM
MaxBoost
53
May 1, 2002 08:41 PM
