rear camber adjustment
Old Jun 13, 2004 | 07:09 PM
Wes V's Avatar
Default rear camber adjustment
I know that it's common to use washers on the upper control arm, moving it outward, to adjust the rear camber.
What I'd like to know is that the total thickness (height of the washer stack) people have had to use and what amount the car was lowered (causing the camber problem).
Wes
Old Jun 13, 2004 | 08:08 PM
crxgator's Avatar
Default Re: rear camber adjustment (Wes V)
cant find it now...it was on h-t before...
Old Jun 13, 2004 | 08:11 PM
Mr_CRX's Avatar
I have skunk2 coilovers and dropped the rears ALMOST all the way down, maybe 3/4" left on the perch or so?
I'm not sure how much of a drop that is, but I think I used two washers on each bolt in the back, and I think they were maybe 1/8" thick each? Something close to that. I dont have my car at my house right now, otherwise I'd go check for you, but hopefully that can help a little.
I added one, and just let the car down onto the ground, eyeballed it to see how straight up and down the tire was or not, and then added another washer and it looked pretty straight up-and-down. I drove several thousand miles on it like that and the tires wore down evenly.
Old Jun 13, 2004 | 08:27 PM
HatchBox's Avatar
Skoobie no more...
Default Re: rear camber adjustment (Mr_CRX)
https://honda-tech.com/zerothread?id=330624
gator didnt look in the FAQ page at the top of the page.
Old Jun 14, 2004 | 01:03 PM
crxgator's Avatar
Default Re: rear camber adjustment (Hybrid Hatchback)
um i did, but that was not the question wes asked...he asked how big are the washers per inch drop...
NY_2_OC
Suspension & Brakes
Feb 3, 2012 09:35 PM
wannaBjdmca6
Suspension & Brakes
26
Jan 16, 2011 08:24 PM
ccivic
Suspension & Brakes
37
Feb 5, 2005 07:51 PM
StRacer
Oct 4, 2004 07:35 PM
FourthGenHatch
11
Oct 1, 2002 07:00 PM
