Car runs great but has NO power
From: the asshole of america..., upstate new york, USA
i dont think that the pr4 is the best ecu to be using...try a pm6 or pg7.
as for code 9:
http://www.binghamtonlife.com/...2.jpg
http://www.binghamtonlife.com/...3.jpg
as for code 9:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zcnos »</TD></TR><TR><TD CLASS="quote">i put pm6 maps in it. i know what im doing.</TD></TR></TABLE> No one said you didn't know what you were doing, you neglected to mention you had pm6 maps on the pr4 ecu. The a6 head on the b2 block is gonna be off by half a tooth..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">obviously you didnt know what you were doing or else you would've set the engine in time correctly the first time
</TD></TR></TABLE>hey ********, did you see what he put? putting an a6 head on misalignes the timing marks. i lined it up like youre supposed to and it ran like ****.
but, to get in intime correctly, you'll need an adj. cam gear. you can't fix half a tooth without adjusting the gear 4.75 degrees retarded or advanced depending on how you have the gear lined up and tdc.
yeah i know, thats why i was guessing at where it goes. it was too advanced, then i moved it back one, then it ran better but i thought it should be even better so i moved it another one and then it was retarded too much. i moved it back to the middle and now i need a cam gear.
hey ********, did you see what he put? putting an a6 head on misalignes the timing marks. i lined it up like youre supposed to and it ran like ****. </TD></TR></TABLE>
Hey beavis, calm down. Clearly he was teasing you by the "
Glad to hear you got it running right. 9/10 times it's something simple like that.
Waachback
14
Nov 28, 2003 01:36 PM
