ITR oil cooler. How does it look like?
Old Jun 13, 2004 | 07:14 AM
RedGSR's Avatar
Default ITR oil cooler. How does it look like?
I know there is a piece of metal with 2 hose that attaches to the oil filter. But where do those 2 hose thing attach to and is there a radiator kind of thing for the oil?
Old Jun 13, 2004 | 10:58 AM
94gsr4dr's Avatar
Default Re: ITR oil cooler. How does it look like? (RedGSR)
What year is your gsr, i know obd1 cars (gsr) came with oil coolers as well
Old Jun 13, 2004 | 11:00 AM
Chris's Avatar
no radiator for the oil. Its just a coolant passage around the base of the oil filter.
Old Jun 13, 2004 | 02:28 PM
RedGSR's Avatar
Default Re: ITR oil cooler. How does it look like? (Chris)
Where does the coolant come from? Is there any hose that attaches to the radiator?
Old Jun 13, 2004 | 05:13 PM
Tweakmeister's Avatar
"how" does it look like?
I've posted a bunch of pictures before, don't remember the thread or name of pic on server though.
Old Jun 14, 2004 | 03:38 AM
Xsi's Avatar
Xsi
You can see how it looks like in the pic, where the oil filter screws on
Old Jun 14, 2004 | 07:55 AM
RedGSR's Avatar
Default Re: (Xsi)
Xsi: Thanks for the pic
Does anyone know if the a 99 GSR engine block has those hole for the 2 coolant hose? Would I need to do anything special to put an ITR oil cooler on?
Old Jun 14, 2004 | 12:59 PM
ThePro's Avatar
I'm pretty sure the GS-R and the ITR came with those oil coolers stock. The GS-R oil cooler I've heard is so ineffective there is arguement on whether it does anything at all.
If you have the ITR oil cooler already then stick it on there, otherwise a nice gReddy radiator type oil cooler would probably do very nicely for you. I have one and the thing I like about it is the fact that I can actually tell a difference. The feed oil line is always a lot hotter than the return oil line. I know that isn't the most reliable way of telling temperature. But it also allows about 1/2 - 3/4 of a quart more oil in the system. More oil means it can store and dissapate more heat.
Old Jun 14, 2004 | 02:03 PM
RedGSR's Avatar
Default Re: (ThePro)
Only the earlier GSR has oil cooler. Mine is 99 and it doesn't have oil cooler I believe the ITR oil cooler is exactly the same the the earlier model GSR oil cooler.
Old Jun 14, 2004 | 03:43 PM
Xsi's Avatar
Xsi
Yeah early B16a's like mine have them too, I believe they are all the same
Old Jun 14, 2004 | 04:06 PM
TheGSRGuy's Avatar
Default Re: (Xsi)
94 & 95 GS-Rs had it. The OBD2 GS-Rs (96-01) did not have it. All ITRs use it.
Unless you race, it isn't really needed.
Old Jun 14, 2004 | 08:29 PM
1stGENGSR's Avatar
Default Re: (TheGSRGuy)
92-93' GSR's have them too........
rcbusiness
Honda Civic (2001 - 2005)
Jul 13, 2017 01:50 PM
longshot
11
Jan 23, 2009 10:56 AM
PatrickFrantz
Jan 11, 2009 08:51 AM
Chubz
May 31, 2002 02:06 PM
