Damn it! New aem intake filter cracked!
Old Jun 12, 2004 | 03:04 PM
escape2me's Avatar
Default Damn it! New aem intake filter cracked!
I just got a brand new aem sri and the rubber on the filter has cracked, damn this intake has given nothing but problems. Also I am still leakin' coolant to the hose under the throttle body that I replaced with the aem hose. Is there a warranty for this? Any help would be appreciated.....
Old Jun 12, 2004 | 03:06 PM
boostinb20vtec's Avatar
call them up and ask...I had to do that with a set of shocks I had.
Old Jun 13, 2004 | 12:21 PM
Stripped Honda's Avatar
99-0104
Default Re: (boostinb20vtec)
aem will warrenty that just write to them or call them .. it looks like you got a old hose or maybe just a defect part .
Old Jun 13, 2004 | 12:43 PM
Street Style Dc2's Avatar
Contact them, tell them about it... they should replace it.
Old Jan 20, 2007 | 06:54 AM
b18cEK's Avatar
Default Re: (Street Style Dc2)
same thing just happened to my filter. hopefully they replace it.
I popped my hood after 2 weeks and I found the filter cracked off and laying by the radiator!!!!
that could have fucked my **** up bad!
Old Jan 20, 2007 | 08:07 AM
mrdeadman's Avatar
They let me pick
Default Re: (ej8pwr)
Maybe it was just screwed on too tight...
Old Jan 20, 2007 | 08:08 AM
95 integra's Avatar
They will most likely replace it....though its likely install error and not their fault. That last pic (posted by ej8pwr) looks like awfully hard rubber for AEM...generally their rubber is much softer then that appears to be.
Old Jan 20, 2007 | 08:20 AM
b18cEK's Avatar
Default Re: (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">Maybe it was just screwed on too tight...</TD></TR></TABLE>
how can you screw it on too tight? it is a rubber material and should conform, not crack
Old Jan 20, 2007 | 09:10 AM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8pwr &raquo;</TD></TR><TR><TD CLASS="quote">
how can you screw it on too tight? it is a rubber material and should conform, not crack</TD></TR></TABLE>
That looks more plastic than rubber and when you screw the clamp down too hard on plastic, it cracks.
Old Jan 20, 2007 | 10:13 AM
__oversea's Avatar
the clamps edge is sharpe. so under havey vibration, it's been cutting the rubber.
Old Jan 20, 2007 | 02:28 PM
juda7's Avatar
From the looks of the pic, it looks as though the "crack" comes right where the edge of the clamp holds the filter on. Maybe?
Old Jan 20, 2007 | 03:17 PM
HomeDepotMade's Avatar
Default Re: (juda7)
man i just got a SRI from aem a couple of weeks ago. but mine was soft rubber.. so i dono man?
Old Jan 20, 2007 | 04:28 PM
OMG THE GOGGLES's Avatar
Default Re: (Hype Vtec)
DO NOT USE THE STOCK AEM FILTERS w/ STANDARD (cheapy) HOSECLAMPS. They do make good products, but I have seen this time after time. The rubber they use is nice and soft and makes for an ultra lightweight filter, but, the hoseclamp will cut into it just by its simple design. The only way to avoid that is using a Tclamp where you dont have the adverse effects of cheap hoseclamps. I suggest running a harder rubber filter with metal top and bottom.
Old Jan 20, 2007 | 04:48 PM
Default Re: (gasp0matikz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gasp0matikz &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT USE THE STOCK AEM FILTERS w/ STANDARD (cheapy) HOSECLAMPS. They do make good products, but I have seen this time after time. The rubber they use is nice and soft and makes for an ultra lightweight filter, but, the hoseclamp will cut into it just by its simple design. The only way to avoid that is using a Tclamp where you dont have the adverse effects of cheap hoseclamps. I suggest running a harder rubber filter with metal top and bottom. </TD></TR></TABLE>
man scaring me to redue my intake now? anyone ever had this problem?
Old Jan 20, 2007 | 11:47 PM
95 integra's Avatar
No, dont stress over it. I ran the cheap hose clamps that came with my AEM CAI for years with no problems. Just make sure you get true AEM products and not cheap EBAY crap with a 99 cent sticker attached to it.
MR. ARIZONA
Dec 29, 2003 10:25 AM
JDMTEG98
Aug 27, 2002 07:19 AM
JumbosGS-R
Aug 15, 2002 05:09 PM
kepani
Oct 29, 2001 02:49 PM
Lang
Aug 7, 2001 03:18 PM
