My AEM CAI is rubbing. HELP!
Old Nov 13, 2001 | 06:45 PM
B2FiNiTY's Avatar
Default My AEM CAI is rubbing. HELP!
I put a peice of rubber hose where the intake meets the AC lines but I just discovered that it has made a little dent in my intake. I'm afraid if this continues there will be a big hole there. What are all your solutions to this problem? Would bending the AC lines affect my AC system? (not that I ever use it much. )
Old Nov 13, 2001 | 06:49 PM
ThePunk's Avatar
Default Re: My AEM CAI is rubbing. HELP! (B2FiNiTY)
You can lightly bend the lines and not hurt the AC system.
Old Nov 13, 2001 | 08:13 PM
B2FiNiTY's Avatar
Default Re: My AEM CAI is rubbing. HELP! (ThePunk)
Hand bend them?
Old Nov 13, 2001 | 08:20 PM
ThePunk's Avatar
yep!
Or you can reverse the bracket that holds them.
Old Nov 13, 2001 | 08:34 PM
Toda Party's Avatar
or just be ghetto and put a little piece of rubber or even folded over paper between the intake and a/c lines and tape it in place...the paper/rubber will take the rubbing instead of ur intake..
[Modified by Toda Party, 5:37 AM 11/14/2001]
Old Nov 14, 2001 | 03:30 AM
yakkosmurf's Avatar
Default Re: My AEM CAI is rubbing. HELP! (Toda Party)
I used some water pipe insulation you can buy at Home Depot. It's already curved, and it cushions nicely. I didn't use very much of it, and I didn't wrap it all the way around the intake tube. It did the job nicely. I switched to the Comptech Icebox, and I have no problems with it rubbing anywhere. It's a much better fit than the AEM was.
Old Nov 14, 2001 | 05:07 AM
Black R's Avatar
25 Year Member
how about using zip ties you guys?
sheesh!
Old Nov 14, 2001 | 05:11 AM
White Dragon's Avatar
Default Re: My AEM CAI is rubbing. HELP! (Black R)
There is a much better fix. On the other side of the tube, where the mounting point is, just drill out the slot a little bit more, and that will allow the whole intake to slide to the left (away from the A/C lines). Takes about 2 minutes
Old Nov 14, 2001 | 07:12 AM
itr0677's Avatar
New User
Default Re: My AEM CAI is rubbing. HELP! (White Dragon)
All:
What is this, rubber hoses, drilling, cutting, zip ties? Are you guys into some weird kinky ****?
Just kidding.
A better solution is to utilize one of the original rubber bolt/screws that was utilized with the original intake and replace the AEM rubber-glue-bolt used by the AC lines (it is too flexible).
I'd take a picture, but my camera is out on loan.
The original intake bolt/rubber combo looks like
Male Bolt with attached female bolt covered by black rubber. So what you do is bolt the left side of the pic down into the car, place the AEM bracket on the top of the female/rubber side and then put a male bolt in. I GUARANTEE this will sove your problem.
Ha! Ingenuity is all it takes....
- Brian
Old Nov 14, 2001 | 07:39 AM
Rory Breaker's Avatar
Default Re: My AEM CAI is rubbing. HELP! (itr0677)
Call me old fashioned or mickeymoused, but I just shoved a chunk of duct tape down where it was rubbing and it worked like a charm for a year
Old Nov 14, 2001 | 08:41 AM
B2FiNiTY's Avatar
I used a peice of rubber but it still rubbed. Had the intake on a few months already but recently checked to see the condition of the area and it was rubbinb a little bit. I'll try the male/female thing.
DynastyRacer22
Mar 9, 2005 07:33 PM
00-0258
Jul 27, 2003 07:20 PM
01-1293
Sep 5, 2002 03:03 AM
B00ST2nR
Mar 5, 2002 10:15 PM
Kendrick07
Jun 19, 2001 12:25 PM
