aem cai install problem
Old Jul 26, 2003 | 05:50 PM
00-0258's Avatar
Default aem cai install problem
has any one here had problems trying to get there aem cai installed i could not get it in i think i might be due to the ac lines
Old Jul 26, 2003 | 06:23 PM
Denny's Avatar
Default Re: aem cai install problem (00-0258)
just move coolant resivoir and use some man power
Old Jul 26, 2003 | 06:28 PM
01-1293's Avatar
Default Re: aem cai install problem (Denny)
anyone know how to stopp coolant resevoir rubbing?......I've tried re-positioning it on the intake manifold and putting little pads between the resevoir and intake
Old Jul 26, 2003 | 06:40 PM
Floyd's Avatar
Default Re: aem cai install problem (01-1293)
AEM rubbing on AC lines is a common problem. I didn't have any trouble with mine, but plenty of people do. Just push them to the side and use a tie-wrap to hold them out of the way.
Old Jul 26, 2003 | 06:46 PM
Jowee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-1293 &raquo;</TD></TR><TR><TD CLASS="quote">anyone know how to stopp coolant resevoir rubbing?......I've tried re-positioning it on the intake manifold and putting little pads between the resevoir and intake</TD></TR></TABLE>
Bend the bracket holding the coolant resevoir.
Old Jul 27, 2003 | 10:04 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: aem cai install problem (George Knighton)
Zip-tie the AC lines together, then use a pad between the AEM and reservoir bottle.
Old Jul 27, 2003 | 04:12 PM
00-0258's Avatar
Default Re: aem cai install problem (Splat)
got it in thanks but i had a ram air on it before and i just took it for a test drive with the aem and the rpm seem to get to 8400 alot faster but vtec dont kick in like it did before any 1 eles seen a differace betwwen a cai and a ram air
Old Jul 27, 2003 | 04:18 PM
B2FiNiTY's Avatar
I'm sure your talking about a short ram intake vs the cold air but if I am wrong please correct me. You want to have VTEC as smooth as possible not to have it kick in.
Old Jul 27, 2003 | 04:22 PM
rated_r's Avatar
mine rubbed so bad that it put a hole in the cai tube... Get a sponge and tape it to the intake to prevent damage that i got
Old Jul 27, 2003 | 05:22 PM
hYpE-R-29's Avatar
Default Re: aem cai install problem (rated_r)
yup just as rated r said, thats what I did. Get a 1-sided sticky sponge and stick it on on the cai..
Old Jul 27, 2003 | 06:16 PM
00-0258's Avatar
Default Re: aem cai install problem (B2FiNiTY)
y is that
Old Jul 27, 2003 | 06:32 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00-0258 &raquo;</TD></TR><TR><TD CLASS="quote">You want to have VTEC as smooth as possible not to have it kick in.
y is that</TD></TR></TABLE>
If the breathing components of your engine create a large spike when vtec engages, they are robbing your midrange. If the crossover is smooth, this usually means the modifications support a strong midrange, which is a good thing.
Old Jul 27, 2003 | 07:20 PM
00-0258's Avatar
Default Re: aem cai install problem (92TypeR)
cool thanks for that bit of info
Sep 5, 2002 03:03 AM
SpoonFed
Jan 29, 2002 06:10 AM
friedsqrl
Jan 25, 2002 12:40 PM
B2FiNiTY
Nov 14, 2001 08:41 AM
6SPD_EK
Jul 28, 2001 08:27 AM
