WHY WONT MY HALF-SHAFT GO BACK IN!?!?!?!?!
Old Jun 11, 2004 | 03:24 PM
zc honda's Avatar
Default WHY WONT MY HALF-SHAFT GO BACK IN!?!?!?!?!
ok i put a new clutch and flywheel in my zc crx with 91 si transmission. That went fine, but i guess my passenger side half-shaft didnt go all the way in then i put it in. But last night when i drove the car for the first time it drove fine (just went around the block). Then this morning when i backed out of my driveway i made a sharp left (going in reverse) when i went from reverse to first gear there was a pop and the car wouldnt drive. So we pushed it back in the grage. The clutch feels fine in the tranny goes threw all the gears ok. when i got home today i looked under the car and found the passenger side half-shaft wasnt in all the way (needed to go in about another 3/4 inch). but now it wont go in. I have been fighting with it for an hour, the splines are fine, i dont know what the problom is,
i can get it all the way in except for about 3/4 of an inch. dose anyone know what the problem might be????????
help please!!!!
Old Jun 11, 2004 | 03:59 PM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
Default Re: WHY WONT MY HALF-SHAFT GO BACK IN!?!?!?!?! (zc honda)
Maybe the splines on the inside of the transmission messed up.
Old Jun 11, 2004 | 04:12 PM
regime's Avatar
Default Re: WHY WONT MY HALF-SHAFT GO BACK IN!?!?!?!?! (Jurassic Four)
stupid question time.. is the snap ring too lose on the end of the axle. normaly you have to just push the axle into the tranny with a lil force.
Old Jun 11, 2004 | 07:01 PM
4DRmafia's Avatar
looks like a spline teeth inside of the tranny is mess up or the clip on the axle is not there
Old Jun 11, 2004 | 10:27 PM
Synth124's Avatar
the clip maybe. hell just beat it with a dead blow hammer, it might not make the problem any better, but oh well.
Old Jun 11, 2004 | 10:40 PM
mr. carpenter's Avatar
Default Re: WHY WONT MY HALF-SHAFT GO BACK IN!?!?!?!?! (Synth124)
are you pushing it in hard? i normally get the axle in the hub and hold the hub like a steering wheel then smack that thing in. also have had to use a rubber mallet to bang it in. if it does'nt have the ring on it i'd get a new one.
Old Jun 11, 2004 | 10:47 PM
4DRmafia's Avatar
Or! maybe it dont like u at all. naw just playing well put the shaft back if the clip not there and get a new 1
Old Jun 12, 2004 | 04:12 PM
yellowcrx13's Avatar
Default Re: (civicsidude91)
ya i looked at it a little closer and the teeth on the other side of the snap ring were chewed up, so i got a new halfshaft and it when right in
thanks
redwards
Oct 29, 2007 10:54 PM
JesseCRX
Jul 22, 2006 02:34 AM
HndGoob
Oct 26, 2004 09:20 PM
daveoner
Jun 4, 2004 02:27 AM
Infamous_Imports
Feb 19, 2004 06:21 PM
