engine resleeving!?!?
if i get my engine resleeved can i run more boost from my turbo? safely that is? i had the crank polished and balance have eagle rods and 10:1 forged wisco pistons at the bottom end
10:1 is not for boost applications at least those that you want to live long. And yes you can run more boost without worrying too much about your cylinderwalls.
9.5:1 would be okay but if you wonna boost alot 9:1 would be better, so I would say 9:1 is a good choice, you don't really wonna go any lower because then you will have alot less power off boost.
