90 civic with 1.5blk and 95 vtec head .....timing problems
Old Jun 10, 2004 | 05:06 PM
91civicw15blkvtec's Avatar
Default 90 civic with 1.5blk and 95 vtec head .....timing problems
i recently shot a piston through my 1.6 block.... i was able to get a 1.5 block with a 95 vtec head. the timing belt seems to only get tight on one side. i think that i have the right belt but is there any thing else that i might need to know to get it running?
please help me
Old Jun 10, 2004 | 05:33 PM
Tad's Avatar
Tad
Default Re: 90 civic with 1.5blk and 95 vtec head .....timing problems (91civicw15blkvtec)
what block
Old Jun 10, 2004 | 06:21 PM
Deemeetree's Avatar
Electrician
https://honda-tech.com/zerothread?id=554053
Read up on that to check if you have the correct timing belt.
What block do you have from the 1.5?
Might have to remove the timing belt again and check if it's the right tooth.
Old Jun 11, 2004 | 05:40 PM
Default Re: (Dimi)
do you know any web sites that i can go to and get more info. on the belt?
Old Jun 11, 2004 | 06:41 PM
ABK's Avatar
ABK
Default Re: (91civicw15blkvtec)
it supposed to be only tight on one side. does your timing match up after you turn the crank over? if it does then it's something else.
Old Jun 12, 2004 | 11:03 AM
Default Re: (ABK)
no it is off after i turn the crank around... it also doesn't turn around smooth it is tight in some places and loose in others.... what can it be?
Old Jun 12, 2004 | 10:26 PM
ABK's Avatar
ABK
tensioner might be messed up, take off the cover and see.
Old Jun 13, 2004 | 07:35 PM
Default Re: (ABK)
i will try that and see if it works.......... thanks.
4doorcivic16
Apr 28, 2010 04:52 AM
kingofnothing
Mar 17, 2009 01:16 PM
yrulkn@me
Jul 2, 2007 06:09 AM
DVPTeG
Jun 30, 2007 09:31 AM
