SI AND 99-2000 diference
Old Jun 10, 2004 | 03:45 PM
dirtyapes's Avatar
Default SI AND 99-2000 diference
just wanted to know what is the difference between the honda civic SI front end and just a regualr 99-00 front end. and how hard is it to put one of tese front ends on an EK thank you
Old Jun 10, 2004 | 03:46 PM
BauleyCivic's Avatar
Risky Business
Default Re: SI AND 99-2000 diference (dirtyapes)
Grille and Lip...just get those don't waste your time and do the entire front end conversion. You need a 99-00 Si Grille and Lip.
Old Jun 10, 2004 | 03:56 PM
Ricey McRicerton's Avatar
Default Re: SI AND 99-2000 diference (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Grille and Lip...just get those don't waste your time and do the entire front end conversion. You need a 99-00 Si Grille and Lip.</TD></TR></TABLE>
Correct sir.
Old Jun 10, 2004 | 04:00 PM
Dc2 Powered's Avatar
i know that the normal 99-00 has no Lip but whats the difference about the grill.. anypics?
Old Jun 10, 2004 | 04:02 PM
Default Re: (Speedin Type R)
The SI grille has some black mesh with the H set on it, while the other grilles are just like every other civic.
Old Jun 10, 2004 | 04:12 PM
=GAME='s Avatar
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">The SI grille has some black mesh with the H set on it, while the other grilles are just like every other civic. </TD></TR></TABLE>
negative. the SI grill has no H. you have it backwards.
Old Jun 10, 2004 | 04:13 PM
Default Re: (=GAMEOVER=)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVER= &raquo;</TD></TR><TR><TD CLASS="quote">
negative. the SI grill has no H. you have it backwards. </TD></TR></TABLE>
Are you 100% sure on that?
Dacalac's Avatar
and if you want pics check the Appearance forum.
Old Jun 10, 2004 | 04:14 PM
99blusi's Avatar
Wrong, the Si grill does come with an H on it, but it's removeable. Most people, including myself remove it...it just looks better without it.
Old Jun 10, 2004 | 04:18 PM
AVA's Avatar
AVA
Sláinte
Now I know why nobody uses the search feature, there is so much wrong information going around
Old Jun 10, 2004 | 04:19 PM
=GAME='s Avatar
Default Re: (99blusi)
whoops my bad. all the si grills i see have no emblem. on me
Old Jun 10, 2004 | 04:21 PM
Tim.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blusi &raquo;</TD></TR><TR><TD CLASS="quote">
Wrong, the Si grill does come with an H on it, but it's removeable. Most people, including myself remove it...it just looks better without it.</TD></TR></TABLE>
Old Jun 10, 2004 | 04:22 PM
Mag00n's Avatar
12. If you are going to post some information and are not 100% sure if it is correct, then please say so.
If there is a tech topic and you have a "pretty good idea" about an answer then please say so. Stating something matter-of-factly when you're not 100% certain can be a terrible thing. Also sometimes you may think you have the right info, so try to avoid posting things in a manner that leaves you no wiggle room if it ends up being incorrect. Use phrases like "I'm pretty sure" or "If I recall correctly" so that someone else can verify your info before someone else takes it as gosphel truth.
Hoffy
Mar 30, 2008 04:55 PM
ibevila
Mar 24, 2008 03:19 PM
ibevila
Mar 23, 2008 01:37 PM
Dead CIVIC
Jan 28, 2008 10:16 PM
ProjectRage
Dec 6, 2007 08:55 PM
