SI AND 99-2000 diference
just wanted to know what is the difference between the honda civic SI front end and just a regualr 99-00 front end. and how hard is it to put one of tese front ends on an EK thank you
Risky Business
Re: SI AND 99-2000 diference (dirtyapes)
Grille and Lip...just get those don't waste your time and do the entire front end conversion. You need a 99-00 Si Grille and Lip.
Re: SI AND 99-2000 diference (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Grille and Lip...just get those don't waste your time and do the entire front end conversion. You need a 99-00 Si Grille and Lip.</TD></TR></TABLE>
Correct sir.
Correct sir.
Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">The SI grille has some black mesh with the H set on it, while the other grilles are just like every other civic. </TD></TR></TABLE>
negative. the SI grill has no H. you have it backwards.
Re: (=GAMEOVER=)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVER= »</TD></TR><TR><TD CLASS="quote">
negative. the SI grill has no H. you have it backwards. </TD></TR></TABLE>
Are you 100% sure on that?
Re: (=GAMEOVER=)
Wrong, the Si grill does come with an H on it, but it's removeable. Most people, including myself remove it...it just looks better without it.
Re: (=GAMEOVER=)
Now I know why nobody uses the search feature, there is so much wrong information going around
Re: (99blusi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blusi »</TD></TR><TR><TD CLASS="quote">
Wrong, the Si grill does come with an H on it, but it's removeable. Most people, including myself remove it...it just looks better without it.</TD></TR></TABLE>
Re: (=GAMEOVER=)
12. If you are going to post some information and are not 100% sure if it is correct, then please say so.
If there is a tech topic and you have a "pretty good idea" about an answer then please say so. Stating something matter-of-factly when you're not 100% certain can be a terrible thing. Also sometimes you may think you have the right info, so try to avoid posting things in a manner that leaves you no wiggle room if it ends up being incorrect. Use phrases like "I'm pretty sure" or "If I recall correctly" so that someone else can verify your info before someone else takes it as gosphel truth.
Dead CIVIC
01-28-2008 10:16 PM
