what size trim turbo? b18b
Old Jun 10, 2004 | 03:19 PM
skunk2eg's Avatar
Default what size trim turbo? b18b
on a stock b18b what size turbo would be good to run at around 7 psi. and how much would the set-up cost$$
-nick
Old Jun 10, 2004 | 03:24 PM
Dacalac's Avatar
Default Re: what size trim turbo? b18b (skunk2eg)
wrong forum bud. Try the Forced Induction...better yet...get a mod to move this one.
Old Jun 10, 2004 | 04:09 PM
alpha's Avatar
I would like to see a B18b here put down some numbers with the Precision GT3251E.
Old Jun 10, 2004 | 04:53 PM
95integraLS's Avatar
Default Re: what size trim turbo? b18b (0x64)
57trim
Old Jun 10, 2004 | 05:32 PM
Burke's Avatar
Banned
Default Re: what size trim turbo? b18b (95integraLS)
te/to4e 67 or 60 trim with a .48ar on exhaust (for faster spool) or .60 for a little more topend. personally if you plan on running stock for a while i think you would be happier with a .48 ar. i would get 7 lbs by about 3500 on a t3/to4b .48 ar on hot. id get 12 a couple hundred later
fyi i ran a 12.7 @ 107 on a stock b18b with that t3/to4b
Old Jun 10, 2004 | 05:41 PM
J337_UNIT's Avatar
Default Re: what size trim turbo? b18b (Burke)
i got a 50 trim t04e series.. it spools nicely, therefore my midrange is great.. however it doesnt really make a huge amount more power after 5,500rpm (but it peaks at 6,500ish) .. i put down 196.7 WHP @ 8 psi and 186 ft lbs ... i bet if i had a 57 or 60 trim i could have put around 220 whp up top but sacraficing mid range..
Old Jun 10, 2004 | 06:25 PM
skunk2eg's Avatar
Default Re: what size trim turbo? b18b (J337_UNIT)
thanks for the info.... would $1500 build a decent turbo kit
Old Jun 10, 2004 | 06:46 PM
no...when my kits done, i will probably have spent around $2,500
Old Jun 10, 2004 | 06:51 PM
J337_UNIT's Avatar
i dropped around 4,000 (way over my original budget)
1500 will be tough to build a "decent" kit.. if you want a reliable kit, which btw i prefer reliability and quality, you will end up dropping a decent amount
Old Jun 10, 2004 | 07:06 PM
cliff666's Avatar
id also like to kno about what size ill b runnin a b20z stock turbo setup and was figuring out which turbo to use i especially since i wanna utilize mid range-high end HP and less about the low end power.
BIG T
Apr 11, 2007 05:34 PM
spoonzdelsol
Oct 7, 2005 07:11 PM
the.hamburglar
Apr 3, 2005 09:09 AM
No
May 24, 2004 08:38 AM
