shift problems?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! »</TD></TR><TR><TD CLASS="quote">you can go into any gear (or nuetral) without the clutch. if ur putting it into a gear without the clutch then as long as ur rev's match then you're good 2 go</TD></TR></TABLE>
there is a good reason our cars have clutches. use it. ill garuntee every time you do that you are shortening the life of the transmission, even if you dont hear a grind. dont be a dumbass.
yes its normal to be able to slip the shifter into neutral but DO NOT DO IT. use the damn clutch.
ablack934doorcivic
Nov 1, 2005 02:02 PM
crxaddikt
16
Apr 4, 2002 05:25 AM
DualKnuttz
Dec 12, 2001 09:46 PM
